HK1 X4
    HK1 X4
    HK1 X4 Amlogic S905X4 Quad Core Android 11
    4GB RAM 64GB ROM, 2.5G 5G Dual WIFI, Bluetooth 4.1
    1000M Ethernet
    4K HD Support Youtube Netflix - EU Plug
    Hi guys got this new Box recently from Banggood
    -very fast
    -pre-rooted!
    -seems a little bit faster then other 905X4 Boxes!
    -no any heat issue
    Note;for "Clarks",it plays VC-1 !!
    1000M Ethernet
    -very fast
    -pre-rooted!
    -no any heat issue
    Dang, I may have to get one an try it. I will wait for more reviews from you for this box. I will see how long you keep it.....
      bergamesk is that the HK1 RBOX X4 that you have?
        Video review here.
          Great review, but NO mention of the VC-1 video codec........
            Hi guys
            -probably "VONTAR" is producer this Brand>> HK1 X4
            and mine is 4/32 version with "1000 LAN" (with yellow col.Box edge)
            because as same model has it 100 LAN too(with Grey col.Box edge)
            -seems that internet speed is very high and stable
            I'v tested both Ethernet&5GHz (not tested 2.4GHz)
            but my internet package covered 100Mb only!
            -Device very cool,no heat issue(but not tested with Gaming!)
            -@Clarkss;I'v many VC-1 contents and its OK to play it and before these boxes (HK1 X4&Tanix X4) no any other Box(AMLogic)
            to play my VC-1 files!
            -This HK1 box seems one of the very fast&stable+very good firmware etc., then other AML 905X4 boxes
            Note;I'v A95X F4 too;it get me crazy right now!
            above review by ""TV Box Stop"" this model with grey-edge type with 100-LAN !!
            Yellow>>1000 LAN
            Grey>>100 LAN
            >stock "GALLERY"(picture viewer) does not work
            >Screen-saver does not work stable!
              I purchase one from Aliexpress. Glad you pointed out the grey and Yellow border for the LAN connection.
                Hi guys
                Yellow>>1000 LAN
                Grey>>100 LAN
                Testing HK1 X4 4 / 32
                Same with yellow col on edge of ** SoapDish
                ** Member from 4pda best described as
                Ha Ha
                Took the Box apart
                Top side PCB is Marked
                HK1_S905X4_4Bit_V11
                2019-11-05
                Sticker on underside of PCB Reads as
                X4 4+32+5235F
                D1230
                Ethernet
                RTL 8211F
                Wifi bcmsdh_sdmmc
                HK 5235F
                2.4 freq wifi was unstable
                Signal kept fading good to excellent
                5.0 all good
                Ethernet good
                Blutooth good
                I like the System Bars
                Also that you can Hide them
                Like Task Killer ( paint Brush)
                Very Fast
                Very smooth
                Help Button on Remote
                Is shortcut to System Settings
                Will overlay/display even during Video Play Back
                Can be handy for changing Audio/Video/Display settings
                Also for Hiding Systm Bars
                Box is Good to Very Good!!!
                I have Firmware for Vontar and Transspeed X4
                Would Like to Test to see differences
                However Need Factory Stock Image for
                HK1 X4 before messing with anything
                More Testing
                Happy Testing
                  Ha Ha
                  Took the Box apart
                  HK1_S905X4_4Bit_V11
                  2019-11-05
                  X4 4+32+5235F
                  D1230
                  Ethernet
                  RTL 8211F
                  Wifi bcmsdh_sdmmc
                  HK 5235F
                  5.0 all good
                  Ethernet good
                  Blutooth good
                  Very Fast
                  Very smooth
                  More Testing
                  Happy Testing
                  Good review, thank you.
                    as I know that and according sale adv. Grey is 100LAN and Yellow is 1000LAN
                    its weird!
                    ahh those Chinese
                      >Wifi;2.5GHz almost every box has BAD perf.!
                      >on HK1 with Wifi;5GHz very good indeed and as same perf. Ethernet too
                      Note;I'v tested only my 100MB package only!
                      y guys if y hv more packages such as 150/200 MB or more pls test it exact results
                      Box has no any WiFi and Ethernet issue right now
                      if y interested in for "Picture" settings,so go to long way!
                      -Device Pref.>>Develp.Opt.>>come to last row and find it "More Settings" and click it>>>"PICTURE" volaaaa its pic. stt. there is
                      and y can change Bright/Contr/Col as well
                      >device very fast&smooth! for my exp. tests this HK1 X4 one of the fastest 905X4 Box! (might be VONTAR X4 as same)
                      I'v no any exp. for the Fimware(stock&ROM etc.,)until now for this Box as well
                      -Gallery not worked(well,its not neccessary for me) I'v used paid version of "TV Photo">>>https://play.google.com/store/apps/d...to&hl=en&gl=US
                      -Screen Saver not worked too,I'v tried some of attacks but failed!
                      -"Main Menu">>KDMC(for KODI access)it comes with 18.9,than I'v uninstalled and install it latest 19.3 version!
                      But y wont be changed this "Main Menu" icons! but no problem for me
                      -A new Firmware expecting!
                        clarkss12
                        FYI
                        some of my VC-1 scenes codecs
                        Format : Windows Media
                        File size : 2.19 GiB
                        Duration : 25 min 46 s
                        Overall bit rate : 12.1 Mb/s
                        Maximum Overall bit rate : 12.1 Mb/s
                        Encoded date : UTC 2012-01-03 22:55:48
                        Video
                        Format : VC-1
                        Codec ID : WVC1
                        Codec ID/Hint : Microsoft
                        Bit rate : 1 b/s
                        Width : 1 920 pixels
                        Height : 1 080 pixels
                        Display aspect ratio : 16:9
                        Frame rate mode : Variable
                        Nominal frame rate : 59.940 FPS
                        Bit depth : 16 bits
                        Compression mode : Lossy
                        Audio
                        Format : WMA
                        Format version : Version 2
                        Codec ID : 161
                        Codec ID/Info : Windows Media Audio
                        Bit rate : 128 kb/s
                        Channel(s) : 2 channels
                        Sampling rate : 44.1 kHz
                        Bit depth : 16 bits
                        Stream size : 23.6 MiB (1%)
                        File size : 1.46 GiB
                        Overall bit rate : 8 118 kb/s
                        Maximum Overall bit rate : 8 128 kb/s
                        Encoded date : UTC 2011-12-30 23:34:12
                        Video
                        Format : VC-1
                        Codec ID : WVC1
                        Bit rate : 1 b/s
                        Width : 1 280 pixels
                        Height : 720 pixels
                        Bit depth : 16 bits
                        Audio
                        Format : WMA
                        Codec ID : 161
                        Bit rate : 128 kb/s
                        Bit depth : 16 bits
                        Stream size : 23.6 MiB (2%)
                        its first time Tanix X4 and HK1 X4 plays those clips!
                        all my other AML905X3/4 Boxes wont play!
                          Developer Options /More Settings
                          Thx For That
                          Can adjust contrast etc..
                          What about Picture Mode
                          Standard
                          Vivid
                          Soft
                          Sport
                          Movie
                          User
                          I dont think that Function Works?
                          What is Key Stone Correction?
                          Need to add these Settings to Main interface / or anywhere
                          Problems with Power Down
                          Box does not Shut Down all the way
                          Add Power Key Definition
                          Shutdown
                          Sleep
                          Etc...
                          I can not get the Gallery App to work either
                          Wallpaper can view images
                          Nova Player can view images
                          VLC player can view images
                          Same with screensaver
                          As posted these are not important features
                          Do not affect Box other Functions
                          Not sure about SU Binary for Root
                          Titanium Backup wont work properly
                          More Testing
                          Happy Testing
                            at least this box need one OTA update to fix these bugs/or proper worked some of functions as well
                            "Gallery" what is this! its not play to view anything! Note;I recommend; "TV PHOTO" paid version(y can find it on GPStore)
                            "Screensaver" not work properly too
                            well this device still going on easy and stable for other matters too
                            about with this price range,Box is OK
