HK1 X4
    ** Credit to member from 4pda for finding this
    ** Ui Mode settings in Apps
    Ui Mode
    Normal
    Desk
    Car
    Television
    Appliance
    Watch
    VR Headset
    Have not seen this option in Other Tv Boxes Firmware
    Maybe is Android 10/11/12 ...system settings thing or
    Developer added?
    Changed Ui Mode in Titanium Back Up App from Television To
    Normal
    Fixed!!!!
    Now have Full Backup
    Changed Ui Mode in Screensaver from Television to
    Normal
    Fixed|||
    Not sure if there was issue to begin with?
    Changed Ui Mode in Gallery from Television To
    Normal
    Half Fixed
    I can see Photos in Background
    However Popup Message overlays
    No External Device connected
    Reset Network Settings
    Seems to have Fixed 2.4 Ghz Band issue
    Holding Steady
    This Box is Fast
    Stable
    Working Great for Budget Box Price
    Would Recommend !!!
    New Daily Driver
    Not much Testing left on this Box
    Time to Sit Back and Enjoy!!!
    An OTA would be nice
    Or Release Stock/Factory Firmware For HK1
    Happy Testing
      Ui Mode
      Normal
      Desk
      Car
      Television
      Appliance
      Watch
      VR Headset
      Developer added?
      Normal
      Fixed!!!!
      Normal
      Fixed|||
      Normal
      Half Fixed
      Holding Steady
      This Box is Fast
      Stable
      Would Recommend !!!
      New Daily Driver
      Happy Testing
      My HK1 X4 is still in transit from Aliexpress..... Thanks for this heads up..
        need urgently a f/w!
        device has BUGs
        yesterday I did it "Factory Reset" and re-install my Apk.s...
        but than such as now "Device OFF" function does not work!(when I'v selected Power Off on Remote)
        first it goes to Off than after 5sec. started again(like a "Re-start") but I'v have selected(on remote) OFF..
        before I'hvnt this issue and Off and re-start functions do it right position
        "Gallery" still do not nothing! (but I do not need this apk. too)
          Will the firmware for the Vontar X4 work?? My box will arrive Monday.
            as I know that this box same as Vontar
            or Vontar is main factory for this box??
            and this f/w is a new ROM or factory f/w?
              Have read most of the Thread/Discussion on 4pda about HK1 X4
              It suggests Vontar and Transpeed are clone of HK1 X4
              Who Knows The Truth
              There are multiply Firmware to test Vontar/Transpeed 1000M or 100m versions
              plus Vortex KitchenMod/ and also an ATV...
              However i like to Heed ReaperMans Warning
              ** Always know How to Unbrick Your China Box before Messing with It.
              Iam most reluctant because others have had success with Vontar/Transpeed
              There is no Stock/Factory image To Unbrick
              So you are stuck with The VontarTranspees
              And have same issues or similar?
              Undecided
              Happy Testing
                well,for a now sit&wait
                there is no more need to heading new adventures!
                th4 Supercelaron released a new ROM for "Tanix X4"(I'v this Box too and its under my Sale list,but failure to sale since about more than 1 month!)
                might be I'll try to install this ROM
                but frankly HK1 X4 more stable&fast Box then TanixX4
                Awaiting another working ROM for HK1X4 too fm Supercelaron as well
                thanks
                  thanks
                  Yes agree
                  Iam testing Superceleron on the A95X X4
                  Happy Testing
                    is there any ROM for A95X F4(X4)?
                    its my second Box in my hand since May/2021
                      No
                      Was Typo
                      Iam Testing Tanix X4 SC BETA ATV by Superceleron on China Box
                      A95X F4
                      Same China Box you Have.
                      Superceleron Rom is Based on Tanix X4 the other China Box you Have
                      You will have greater success/More functions testing on Tanix X4 than the other Box
                      Happy Testing
                        I'm not interested in with this new ROM right now
                        "A95X"(the main producers of this Brand)
                        released couple of as "same" Boxes too!
                        with a new "CASE" and it says "NEW" brand/model etc.,!
                        Hereafter I'll never buy any "A95X" Box!
                        and probably I do not willing wanna to buy a new "S905X4" too!!
                        well,its enough for me
                        I'v now in my hand 3 Box; and all is as you will see "905X4"
                        Tanix X4(nob-not good but I do not like it)
                        A95X F4(with on/off issue)
                        HK1 X4(at present as it seems then more stable&fast the others)
                        I guess 905X4 is over!
                        awaiting such as 906 or 905X5..... hahhaaaaaa
                          Received my HK1 X4 today. So far, it is a decent Android box. However, it still does NOT play the VC-1 codec. Waiting for modded firmware's.
                            HK1 X4 is 1000 LAN
                            HK1 X4S is 100 LAN
                            correct ?
                              Originally posted by JoseM View Post
                              HK1 X4 is 1000 LAN
                              HK1 X4S is 100 LAN
                              correct ?
                              I went by the color code of the body of the device.
                              HK1 X4 Amlogic S905X4 Quad Core Android 11 4GB RAM 64GB ROM, 2.5G 5G Dual WIFI, Bluetooth 4.1 1000M Ethernet 4K HD Support Youtube Netflix - EU Plug ++ Hi guys got this new Box recently from Banggood -very fast -pre-rooted! -seems a little bit faster then other 905X4 Boxes! -no any heat issue ++ Note;for
                                yes its correct
                                1000 LAN= Yellow col. (my Box Yellow)
                                100 LAN=Grey col.
                                Hi Clarkss12
                                well its surprised to me that your VC-1 files not played
                                but might be some of format/codec/etc., were different type but mine is OK(as I gave you my some of codec infos on previous pages)
                                as all those files wont played AML Boxes(before and still AML 905X4)
                                except Tanix and HK1 now played!
                                meanwhile Box need a good/stable/proper etc., firmware asap
                                Note;Remote controller kinda bad!
