Actually, this box performs quite well and does everything I expect it to do. Everyone uses these boxes differently.
HK1 X4
seems that this VC-1 files problematic to play it in every Box
-my main and only one issue(at present) the box never goes OFF!
I'v selected on the RM and "Power Off" and Box Re-Started after 10 sec.
it does first OFF and than re-opened!
I do not find any proper/releated menu function to fix this
who is the manufacturer? or are they visited Frektab!
come on guys where are you hahhaaa
clarkss 12
Nice Job on the U-Tube Review !!!!!
Picture quality on HDR 10 that was Spectacular !!!!
You are still Testing VC-1 playback i see in Kodi Interface
Looked like that was an VC-1 MKV INterlaced ...
In the old days with Kodi turn off Hardware decoding Worked/ helped with
Have you ever tested Different Media PLayer?
Getting off Thread Topic
My Bad
This Box is performing quite well!!!!
Could use some Tweaks OTA ...
THanks for the review!!
Happy Testing
My Bad
Happy Testing
Yes, sometimes turning off the hardware decoding does work under Kodi with an SoC that is powerful enough to transcode it. I have not tried it with this box, but it MAY work, I had forgotten about that solution under Kodi.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
my VC-1 files is 1080p - Frame-rate; 59,xxx and its plays OK with "MX Player" BUT failed to play with KODI !!
Kodi opened the file than freeze/stop/lagy so on.... so,KODI doesnt play
BTW Default device Media Player;it plays! without any issue
But might be frame-rate;23/24.xxx wont play(I did not try yet)
Note;might be KODI will play if you disabled/off HW+ decoding!
I prefer Kodi for audio only
I prefer MX for video only,but audio is not good too
and awaiting firmware/update !
Originally posted by bergamesk View Postmy VC-1 files is 1080p - Frame-rate; 59,xxx and its plays OK with "MX Player" BUT failed to play with KODI !!
complete name : \\Beelinkgtr\f\Media\Movies\Blueray Moives\Action\Back to the Future Part II (1989)\Back to the Future Part II (1989).mkv
Format : Matroska
Format version : Version 2
File size : 26.1 GiB
Duration : 1 h 48 min
Overall bit rate mode : Variable
Overall bit rate : 34.6 Mb/s
Movie name : Back to the Future Part II
Encoded date : UTC 2018-12-06 19:31:35
Writing application : MakeMKV v1.14.2 win(x64-release)
Writing library : libmakemkv v1.14.2 (1.3.5/1.4.7) win(x64-release)
Video
ID in the original source medium : 4113 (0x1011)
Format : VC-1
Format profile : Advanced@L3
Codec ID : V_MS/VFW/FOURCC / WVC1
Codec ID/Hint : Microsoft
Bit rate : 28.5 Mb/s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.573
Stream size : 21.5 GiB (82%)
Language : English
Default : No
Forced : No
Original source medium : Blu-ray
Originally posted by c_mayur View PostI got this box but looks like google play store does not have all the apps. I tried searching for brave browser snd nothing came up. When searched from google it says not compatible with your device. TV box has android 11. Not sure how to install it.
Device Preferences
About
This Box uses Android TV OS Build
It is/ has a different version of Play Store...
So just use preinstalled APKPure app
Search Brave
Install
Should be good to go
Testing now
Happy Testing
Keep in mind guys;dont change the version of "PlayStore" because of the installed new version doesnt compatible with yr device!
So,select "ignore"!(for the PlayStore installation)
Since last year to now on;seems that all Andro-10 and 11 Boxes has little bit problematic!
Andro-9 is OK(with Root or w/o Root)
But Andro-10/11(with pre-rooted or not)kinda problematic!
I hvnt any clear idea for upcoming such as "Andro-12" has more stable&efficieny then 10&11 ???
Originally posted by bergamesk View PostKeep in mind guys;dont change the version of "PlayStore" because of the installed new version doesnt compatible with yr device!
I hvnt any clear idea for upcoming such as "Andro-12" has more stable&efficieny then 10&11 ???MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
All eyes seem to be on the new RK3688 SOC, which from what has been seen so far is a beast out of the box and a quantum leap ahead.
Open source development on the S905X4 is reportedly likely dead on arrival because of the bootloader being locked (the next S912 as somebody put it), so may perhaps not be as popular as hoped.R-TV BOX S10, Beebox N3150, Chuwi Hibox, Nvidia Shield, A95X Max
There are currently 1888 users online. 1 members and 1887 guests.
