Well my first rom for a S905X4 device based on android 11.
Nothing from the STOCK rom was used, this is a clean build done from my own Amlogic Android 11 sdk.
AIRMOUSE MANDATORY FOR PROPER USE...
REMEMBER THIS IS A BETA!!!
Changelog v2.0:
- Added proper root.
- Added Mobile settings (like the phone's)
- Dual launcher (choose the one you want on 1º boot)
- Fixed choosing the default launcher. (use Mobile settings to do so)
- Added root on/off switch, it on by default! (restart required to take effect, after each change)
- Added overlay that shows cpu speed/temp etc.. also network speed etc..
- Added option to choose the default UI for each app ( see app info page, only on side settings )
- Added power button to the navigation bar.
- Added Switch OS (if no usb stick or SDcard is present with other OS. it will boot to recovery)
- Fixed sound overlay not working in "Normal" Ui.
- Added Regular Playstore.
- Added Recents Apps.
- Fixed Login in Regular Playstore with Normal UI.
- Fixed lots of permissions.
- Fixed SPDIF output (i think... i do not have a way of testing it)
- And many other stuff...
- Build from latest AML R(11) SDK
- Multi Wifi & Multi BT.
- Added SC Settings ( Some useful options in there )
- Fixed some other permissions.
- Fixed Audio playback in Google Videos (and others)
- Added root (you wont get a pop up asking for permission, it will always give root to any app so... use legit apps !!!!)
- Fixed SDCARD detection
- Fixed front display ( Tanix X4 )
- Some small changes to the ETH to see if it becomes more stable
- Small change to the BT.
- Added support for EXT4 filesystem ( still in testing...)
- Added A95XF4 remote control.
Still missing:
- TWRP.
- Of course there is bugs!! there always be bugs!!
Want to buy me a beer?
Download:
Install instructions:
THIS ROM DELETES ALL YOUR DATA SO DO A BACKUP!
USE AT YOUR OWN RISK!
Enjoy it!
