[ROM] Tanix X4 SC "Normal" v2.0 USERDEBUG - S905x4 - Android 11 - Multi-Wifi&BT
Great job!
Thank you for adding a few features that I wrote about earlier, but there are also some drawbacks that I would like to inform you about:
I will divide them into what does not work, and what I would like personally, in terms of expanding functionality and usability.
1) SPDIF sound - works, but only in stereo mode. If you choose AC3 5.1 or any other - the receiver does not switch modes and there is no sound.
2) Problems with the rotation of some applications, regardless of what the settings are. (for example, the CPU trotting program) I recorded a small video demonstration.
1- Good to know, and yes i know about 5.1 not much i can do about that atm, its complicated how sound works in android there is to many factures involving the support for 5.1/7.1.
2- yes i know about that issue, i wills see if i will add the "force land" to the sdk in a near future.
Thks for the testing .
Originally posted by messure View PostWi-Fi on the fn-link module does not work normally. On the 2.4 band with Bluetooth turned on, it does not work. It is impossible to call this build normal, since the prefix is supplied in two versions of the Wi-Fi module.
and remember i did this build for the tanix x4 and no other device!
And yes i know about the fn-link issues, like i said is a driver issue on my sdk and i already asked for the new fixed driver still did not get it...
I want to use this new Custom OS..
superceleron you mentioned this ROM needs AIRMOUSE MANDATORY FOR PROPER USE
Will this work?
Originally posted by russo.pt View Post
My Tanix x4 4G 64gb is the same as yours
I saw your private message but could not figure a way to reply to that so I hope you can read this.
Yes I did manage to install the Superceleron Rom and in fact it is working very well. I used a home built male to male USB cable to connect to PC and I found this only works when connected to the secondary USB port, that is the one with the black separator. When I tried to connect to the one with the blue separator the PC did not manage to see the box even though this connector should be faster and better.
I also had a few issues with the software since the included help file did not agree with the way the software needs to be set. Unfortunately, since this was done some time ago, I do not remember what I did different to get things to work but I do remember that it was not complicated so you should manage with a bit of fiddling.
Good luck.
Originally posted by russo.pt View PostHi i think it is The cable male to male USB --iam going to buy another one and see if i can do it
Did wifi work and lan ?? what was the speeds ??? - Thank you
Yes both wifi and lan work. I use wifi mostly and it works fine to watch high quality videos so speed should be quite good. Sorry I cannot quote actual speeds.
There are currently 1621 users online. 0 members and 1621 guests.
