[ROM] Tanix X4 SC "Normal" v2.0 USERDEBUG - S905x4 - Android 11 - Multi-Wifi&BT
Yes do plan to keep it updated, just need some free time from work to start fixing some issues on the normal and atv builds.
Always liked your firmware
I am trying build kvim source for vontar x4 lan 1000,
but so far without success, on yours firmare no wifi 6335, lan JL2101 (rtl8211f). Sadly
Originally posted by superceleron View Postwell i added a few more wifi drivers to my next build, it wont be the "normal" but the ATV for now.
The lan, i cant remember if my kernel has support for it, but i will enable the generic rtl driver... just not sure about the pins on the device tree.
Now I'm trying to get openvfd, but so far without success.
Originally posted by Lion_E3 View PostThanks, but it will help. Everything is more complicated there with jl2xx1 https://github.com/unifreq/linux-5.4.../jl2xxx-core.h. But I did it with the boot and vendor_boot substitution, but sometimes I get the my app error, there is no such thing on the tv version mod vontar x4(1000) https://fex.net/ru/s/mnrrzcf
The openvfd you also need to replace the device tree and possibly also the kernel to make it work.
Just replace te _aml_dtb.PARTITION(this is the device tree) and the boot_a.PARTITION(kernel), you also need to make changes to the system... this one is way more complicated!!!
superceleron
gbox23 has shared a TWRP Recovery for the Amlogic S905X4 Android TV boxes.
Cannot attach. But here's the link:
https://drive.google.com/file/d/1Pnu...usp=share_link
Taken from this Google Drive folder:
https://drive.google.com/drive/folde...pn5_n-_2HYryls
Please test and confirm if it works on the Tanix X4.
Originally posted by superceleron View PostOk i will add it to the next build so no need for using a sdcard or a usb stick
As gbox23 claimed it is a "Temporary" Recovery only.
This means it can only be loaded using an SD Card and Pressing the Reset button during the boot-up process.
It would be amazing if you can incorporate this into your Build as a PERMANENT solution. This is one of the critical things that's missing from your fantastic Custom ROM for Tanxi X4 Amlogic S905X4 Android TV Box.
Looking forward to the same and the Android 13 Build as well.
Originally posted by cyntek View PostOk, I have installed this MOD on x96 x4 Pro 1000MB successfully, however there are minor issues.
1. Wifi does not work.
2. The ONN 4k Remote works awesome with it.
3. Ethernet hard line does not work.
4. Rebooting the device did not make a difference.
"normal" means Mobile playstore, nothing else!
and remember i did this build for the tanix x4 and no other device!
And yes i know about the fn-link issues, like i said is a driver issue on my sdk and i already asked for the new fixed driver still did not get it...
superceleron Please embed the Wi-Fi driver for the Fn-Link K255B-SR in your build. Here's the Product Link.
It is a Basic 1T1R 5G Wi-Fi BT Module. with BT5 and WiFi clubbed together.
Is the Fn-Link chipset driver embedded in the ATV build?
There are currently 1738 users online. 0 members and 1738 guests.
