OTT M8S advice for non working unit
    Very new to all of this!
    TV boxes, etc.
    Could not find a forum for OTT boxes.
    Please direct me to it, if it exists.
    I was given an M8S OTT box and am trying to get it to work.
    I have plugged it in to my TV [HDMI cable].
    I have connected it to the internet via cat cable.
    When I turn my TV on all I get is a M8S logo that states mlogic, H.265, 8 core, Mali 450 and Quad Core A9.
    I have downloded the users guide but it is not a lot of help in the info department.
    There is a USB dongle in a USB slot at the back for a bluetooth keyboard, the keyboard lights up, but again no reaction from OTT box.
    The box that the keyboard came in says it is for an Android TV Box.
    There is also a remote for the TV box.
    The remote flashes red when I hit buttons but does not seem to react.
    The remote does not seem to turn machine on/off.
    I have found a site that shows how to reset to factory defaults.
    I have read about getting into recovery mode using a USB keyboard.
    I have not done either.
    Can anyone suggests what my next moves should be?
    Thanks​
    Boot into recovery and reset box to factory defaults...
      TV boxes, etc.
      Thanks​
      Hi ,
      think it is in Bootloop , you must flash new , you must know what CPU is used , Amlogic / Rockchip or others ,
      and what Wifichip is used , then you can search for the right Firmware , think you must open up , to see what
      is going on inside your Box , if all is checked you can download FW and flash with the specific Tool ,
      i think it is S812 Amlogic , very old , better if possible you buy a new one with higher Android Version ,
      you can get good S905x4 Boxes for about 50-60 Bucks , example Tanix X4 / or F95X , remember there are
      small Limitation in use , no DRM L1 for HD Netflix and others , Link for your Box :
      Well, I have a TV box marked OTT Model M8S, I put an incorrect ROM, and it was dead, but I found a firmware, this: cyx_m8s_v8.6_ap6330_8g2g_kodi_addons_ota_150908_USB that with the fire engine, at least The blue light worked, but when turn on, keep the image of amlogic s812 on the TV and do not move on, a firmware for my chip
      https://drive.google.com/drive/mobil...usp=drive_open
      Superceleron made a Customrom for the Tanix X4 look here :
      https://forum.freaktab.com/node/8284...e15#post831478
      further good luck
      greetings / gefattern
        When you boot to recovery (toothpick method/or other
        Top left corner will be firmware info with andriod version
        Make a note of that/take pic with phone
        Kit Kat or marshmallow....maybe...
        Is best get something newer
        Happy Testing
          freddy
          I don’t seem to be able to boot into recovery mode using the toothpick method. Is there another way?
            mmAtvXk device would not boot into recovery mode. Is there another way.
            @getfattern -I have opened device and looked in side -boards look OK.
            The splash screen says Amlogic. How do I find out what the wifi chip is?
              freddy
              Now you are entering into the Testing Zone !!!
              There are other ways...
              Toothpick method is not always works first time.
              Remove usb dongle for keyboard
              And any other external.
              Need more info.
              Any markings on back of box
              Ram
              Rom
              The point is
              Probably as posted s812
              Maybe could be used for emulator
              Older
              LibreELEC
              EmuELEC
              AlexELEC...
              otherwise useless
              Waste of time
              Happy Testing
              • gefattern
                gefattern commented
                Editing a comment
                that is a true comment
              First and foremost, thank you to everyone who has helped in this matter. I do understand that this is an older piece of equipment and my knowledge of it is on the low end. I was hoping that being a Linux derivative there was some hope for it, as I don't like waste. There are few markings on it, which doesn't help. As well as my inexpertise about these devices.
              So, now, I am looking for a "brand" name tv box (other than chromecast, roku, fire, etc.) that I can look into. Not really interested in used. Android(configurable) preferred. I live in CANADA if that makes a difference. My use for the tv box is mostly news and documentary with a little entertainment thrown in. Netflix, et all, I am not interested in, although I like movies. I have cut the wire so to speak and do not subscribe to any of the big TV/Internet providers.
              I do not recognize any names of the Android TV boxes I have seen in any internet searching, so, if someone could provide some names that are good equipment in this line, I could check them out and get on with this.
              ​​​​​​​Thanks.
                Thanks.
                Hi ,
                if you really want to buy a new one , i can suggest you Ugoos Devices , the new X4Q looks good ,
                it has a S905x4 CPU , Mali 31/MP2 GPU and important DRM Widvine L1 for Netflix and other Apps
                to play in HD , L3 only 480p , Dolby Sound available , best Firmware on ChinaBoxes , look on YT for
                Info , maybe i buy the X4Q , hope you can find something ,
                This Thread is here for posts of SD images for Amlogic devices that Boot directly into Linux from sd Card. Special Thanks to balbes150 for all his work in this area This is for Any Amlogic SD card Image for any Distro that is Confirmed Working. As this is the Start of this Thread the Images will be listed in this manor. 905
                and you can look on LibreElec Forum too , a Kodi Fork ,
                  gefattern Is the Ugoos you suggested a "fully loaded" box? If not where would I get the additional software? Ugoos is not available in CANADA, but I can get it from the USA or China.
                    You are required to do your own research/reading. .
                    When choosing a Device
                    Use big G
                    Search
                    There is Ugoos Store
                    And other links...
                    Maybe if you have Amazon
                    Change country
                    And search
                    Amazon. Eu
                    American also ships to Canada
                    Also direct from China
                    Aliexpress
                    I forgot
                    Watch the u tube video review s
                    Great info there on Specs
                    Happy Testing
                      The Advice i give if you want to stream the Big Boys properly, Netflix, Amazon Prime etc, go for a certified box that can work in your area
                      A simple Fire stick can do just about most to watch Paid services, if that is what you seek.
                      Now to fiddle and muck around with you need something else, Ugoos as mentioned or many more that can be found
                      As mentioed above Google is friend, as is YouTube.
                      It Just depends what ya wanna do with it.
                      Also look at resent post on Freaktab to see what being worked on last month or so.with updates and mods
                        Hi ,
                        if you mean a installed Firmware , yes , but remember what Trebor wrote , what are your needs ??? ,
                        for Streaming a Fire Stick or similar is good enough , no need to pay more Money as needed , but
                        that is your choice , if you decided let us know ,
                        further good luck / gefattern
                          How's the decision making going?
                          If you decide to go with a tester
                          Here is list of 5 I have
                          All working with different chipsets/CPU /Android versions
                          Scishion V88 RockChip with Android 7.1.2
                          WeChip V10 Allwinner/custom rom from XDA Forum
                          Android 10
                          Tanix Tx5 Plus Deluxe Amlogic S905X3
                          Custom Rom Android 9
                          With CoreELEC on external
                          A95XF4 Amlogic S905X4
                          Custom Rom Android 11(Superceleron version 6)
                          Hk1 RBox X4 Amlogic S905X4
                          Also Tanix X4 box is the one that Superceleron has
                          So allready is Custom Rom
                          All work with varying results/glitch
                          Nothing is perfect...
                          Personal I would avoid Rockchip/Allwinner
                          Stick with Amlogic
                          Tanix Deluxe performs as well as S905X4 boxes..
                          Happy Testing
                            Hi ,
                            why shall he avoid it , the Problems are the Firmware , if he buys a supported Box , no Problem ,
                            or Ugoos , they have good Firmware , you self are using Amlogic & Rockchip Boxes , his needs
                            are important for his choise ,
