And yes i still support the X4.
[ROM] Tanix X4 SC ATV v6.0 USERDEBUG - S905x4 - Android 11 - Multi-Wifi&BT
Hi , i know , but why only 100mbits , is 100 not fast enough , if Wifi works no Problem , until now my Contract only has
max 50Mbs up and 10 Mbs down , so no Problem , it is only 50% so fast as the Ethernet can handle , or ???
Well if you only have that, then is enough i bet you going to be using WiFi anyway.
Originally posted by MOB-TECH 67 View PostNice.
Which BT remote do you Use that Works Fully and syncs to the Pairing instructions please ?
all worked, but on some lets say the numeric keyboard did not work.
You have to try it.
Originally posted by astronman View PostI have tryed this fimware on my A95X F4 but it wan't pass language selection. Any language I select it reset language section.
But i know of other ppl who use this rom on that device and as no issues with language selection.
Try to reflash the rom again, it might help!
My WiFi chip is Mediatek ARM MT7668RSN.
Originally posted by TirtaAgung View Post
Have you tried slimbox tanix x4 rom? I don't know what my wifi chip is, but i guess the problem you have with superceleron rom is because it force you to enter network settings, as you cannot skip it and your wifi chip is not supported by the rom.
There are currently 1931 users online. 0 members and 1931 guests.
