[ROM] Tanix X4 SC ATV v6.0 USERDEBUG - S905x4 - Android 11 - Multi-Wifi&BT
Originally posted by yayo1702 View PostI was talking, if you use the back key and the left key of the remote control, but hey it's not a big problem
Originally posted by yayo1702 View Postand for local update it puts me black screen
Ho that? is not a bug e more of a feature of Android that is present since android 5 and is still present in android 12 at least on ATV mainline.
?? weird i tested that myself at least 6x time and did not had a issue with local update, remember my local update zip is only to update from my own roms, if you are on the stock rom it will give that issue!
Originally posted by Yakkoymw View PostGood afternoon, does it work on Mecool KM6 Deluxe? I need root on KM6 Deluxe. Sorry for my English.
I installed your rom on my box, at first almost everything worked, including the wifi, but the box keeps restarting all the time. Now I can't go back to the original rom, because I only have the ota firmware and I don't have the rom in img, help me please?
https://drive.google.com/file/d/14zB...ew?usp=sharing
Originally posted by paradox1453 View Post
Is there a simple-to-use program you can recommend? Simply to change the boot screen, fix the controller incompatibility, or adjust the front led display setting.Android firmware kitchen for amlogic devices. Contribute to althafvly/AmlogicKitchen development by creating an account on GitHub.
it will work up to android 9, it will not work correctly on android 10/11/12 i mean it builds the img ok but the once you flash the img it wont work on those versions of android.
This is an advanced user tool.
Thanks for everything.
Originally posted by Leo Silva View PostDoes this rom work well on A95X f4?
Company's stop sending me devices long a go, so im stuck with what i get from my work, since im not buying any device.
Hello!
Thank you so much for making the firmware.
I have an A95X F4 device and I have only tested version 4 so far.
And I have some questions, for example:
1) spdif optical sound doesn't work, it just doesn't glow
2) The built-in samba server is very lacking
3) It would be great if it was possible to open the upper and lower curtain at will.
4) It was very frustrating that I can't use the device without necessarily logging into a Google account, i.e. I couldn't skip this step during the initial setup
5) some programs do not have a full-width screen, but like in a phone
6) the display on the front panel does not work
I understand that the firmware is for TANIX, but I would still like more ;-)
Originally posted by MaxJumper View PostPS: And a lot of unnecessary unnecessary software from Google, imho. (to tell the truth, except for the google.play, I would generally prefer to delete everything)
There are currently 2314 users online. 1 members and 2313 guests.
