[ROM] Tanix X4 SC ATV v6.0 USERDEBUG - S905x4 - Android 11 - Multi-Wifi&BT
Originally posted by freddy View PostTesting on A95X F4 S905X4 4/32
Ethernet only
This is wifi/blutooth combo for A95X F4 mtk_sdio
MediaTEK 7668RTN
There is no support for this in Rom could not pair blutooth remote
so took quite awhile to enter system/setup.
Logitech K400 plus Enter Key Function is the letter q
Finally a generic $5 wireless mouse solved the issue
Having HDMI CeC allready enabled helped with Navigate/ Samsung TV Remote works
Sluggish at the start
After Factory Reset
And muitple restarts it is improving
Getting faster/more stable
Even without wifi/blutooth it is allready outperforms Stock Image Android 10 from A95X F4
I never worry about Front Display( Can be distracting During Movie Playback Light glowing in the Dark)
Nice Job Superceloron!!!
More Testing
Happy Testing
All that i have found is that the A95X F4 box has a AW3155-50R Sziton 1X1 Chip https://fccid.io/VYVAW3155-50-50R/Us...Manual-5445631
or a CDTECH 47W3155 1x1 Chip https://usermanual.wiki/CHINA-DRAGON...55-5424024.pdf
But the MediaTEK 7668RTN is a 2x2 MIMO Chip.
I mean this box:
Originally posted by Anddude View Post
Where have you find that this box has a Mediatek 7668RTN ?
I mean this box:
The First versions came with Android 10 OS
And the 7668
And probably other/different chipsets
Instead of uograding Box to Android 11
Vendors made new Boxes with Andrew 11 and wifi chipsets you posted
So you would have to purchase a new Box
Happy Testing
The Tanix X4 set-top box has an fn-link wireless module installed. On the factory firmware, you can disable Bluetooth and then the WiFi 2.4 speed becomes 30mbps and does not fall off. On your firmware, the speed in the Wi-Fi 2.4 range is 15mbps. Bluetooth couldn't find how to turn it off. Is this a bug in the firmware or in the hardware due to the conflict of Wi-Fi 2.4 with the Bluetooth module? I put beta 3.
Originally posted by messure View PostThe Tanix X4 set-top box has an fn-link wireless module installed. On the factory firmware, you can disable Bluetooth and then the WiFi 2.4 speed becomes 30mbps and does not fall off. On your firmware, the speed in the Wi-Fi 2.4 range is 15mbps. Bluetooth couldn't find how to turn it off. Is this a bug in the firmware or in the hardware due to the conflict of Wi-Fi 2.4 with the Bluetooth module? I put beta 3.
well what i recommend for now is you disable the BT over adb on the ATV build until i add the bt on/off on it.
Code:To enable: adb root adb shell service call bluetooth_manager 6 To disable: adb root adb shell service call bluetooth_manager 8
Originally posted by NEDM64 View Postsuperceleron Hi, can you make this rom for the X96 Max Plus Ultra?
Max you can do is try this one on that device and see if it works, but make sure you know how to set it in mask mode in case it does not boot...
Originally posted by messure View PostThere is a new build from the manufacturer. The 2.4GHz Wi-Fi and the Bluetooth module started working simultaneously on the fn-link chip, but the Wi-Fi speed drops twice at the same time. Speed low, but it work!
There are currently 2296 users online. 0 members and 2296 guests.
