I have a Bluetooth remote control G 20 Pro with ATV version 2, Android assistant went without problems now with version 3 the Google assistant does not work where is the remote.conf
[ROM] Tanix X4 SC ATV v6.0 USERDEBUG - S905x4 - Android 11 - Multi-Wifi&BT
Originally posted by Nambo View PostI have a Bluetooth remote control G 20 Pro with ATV version 2, Android assistant went without problems now with version 3 the Google assistant does not work where is the remote.conf
The only thing i did it was updating the google apps to the latest ones, maybe something on the apps broke it.
I will revert back to the old ones to see if it was that.
And its not the remote.conf, its a kl file with the hw id of that bt device.
Well v4 on its way.
If you guys do the OTA way then a factory reset is needed after it or else the issue will continue, this if you are on V3... But if you are on V1 or V2 then a factory reset is not needed.
If the IMG way is done of course the factory reset its not needed, since the flash already does that for you...
Originally posted by Fshd View Posthello, I have installed this rom in my tanix x4 and it has remained in continuous bootloop, can someone help me to recover the box???
Boot to Recovery (Toothpic Method)
Wipe Cache
Wipe Param Partition
Wipe Data Factory Reset
Reboot/Restart
Good Luck
Happy Testing
ok you just want to put that backup on the device?
if yes i recommend using x-plore file manager, you can install it from playstore, and open it.
Where you want to put the files are in the "internal shared storage", expand it you will see in there "Android" expand that one and then you see "data" and its in there you want to put your backup.
This is all i can say since im not sure what you trying to restore.
ignore the su thing, that is for more advanced users.
There are currently 1116 users online. 1 members and 1115 guests.
