the biggest issue is that after i turn it off, I cannot turn it on with the remote, is thre a way to fix that?
[ROM] Tanix X4 SC ATV v6.0 USERDEBUG - S905x4 - Android 11 - Multi-Wifi&BT
Any recommended rom for a95x f4? tried few roms, non of them is perfect, obviously I'm not looking for a perfect one, right now I'm using the latest from superceleron, the remote is working but the top led and front display don't work.
Originally posted by shemeshrelly View PostAny recommended rom for a95x f4? tried few roms, non of them is perfect, obviously I'm not looking for a perfect one, right now I'm using the latest from superceleron, the remote is working but the top led and front display don't work.
Keep in mind this Rom is based on Tanix X4 S905X4
You will not have RGB light on top
Or VFD front clock/display etc..
I also have no wifi
Ethernet only
Iam testing superceleron atv V4 on a95xf4 s905x4
did not do OTA V5
Remote control is working fine here
Turns box off
And on
No probs
By default CeC is enabled
So can also use TV remote to turn Box On/Off
This function also turns TV off at same time as BOX
With a95xf4 REmote or TV remote
Happy Testing
Originally posted by gavranpero View PostFlashed that rom, the same thing happens.. Anyway, I expect a Rii keyboard with a touchpad, BT or RF, one will work.
Thanks for the help and advice.
New valide date ROM - 20220620
Are there any file explorer apps for this build that will allow me to move files in the android data folder? I had a version of Mi Explorer Api 29 but it does not work for this ATV version but the Standard version it did.
Edit* - I managed to use Root Explorer version 4.9.1 to do what I needed.Last edited by ndsports; 12 November 2022, 03:06.
Originally posted by ndsports View PostAre there any file explorer apps for this build that will allow me to move files in the android data folder? I had a version of Mi Explorer Api 29 but it does not work for this ATV version but the Standard version it did.
Originally posted by nowy View PostI have Tanix X4 and can't install any ROM on it.
I tried to connect the computer with a USB cable and run from a pendrive and SD memory card.
Every time it boots into standard recovery mode and that's it.
Forget PC fir a minute
Hook box up to TV/Monitor
Then Factory Reset
From recovery or system/settings
Make sure you only have 3.20 installed and drivers.
On PC
Open up 3.20
Load image
Hit Start
Now hold in Reset
Plug USB Male to Male
Should catch/load Firmware
There are many variables in connect to UBT
Good Luck
Happy Testing
Originally posted by nowy View PostMy box seems damaged either blocked. I have installed amlogic drivers and Amlogic USB Burning Tool 3.2. I was restoring factory settings. And still windows can't detect my box.
Male to Male USB cable is good
Are you using USB/OTG port on box(not blue USB 3.0)
Do you have another box to test cable/confirm
UBT is recognized?
There are currently 1938 users online. 1 members and 1937 guests.
