Hello. I've been trying to install magisk for several days. but I only get brick. Is there any way to install or use adaway? Thank you very much for the rom. On my KM6 I always had to turn on the wifi when starting and with your rom it works perfectly.
First off, it is a delight using your ROMs Superceleron.
Today I installed the Android TV version since that had additional updates. I still noticed that VPN-services like the NordVPN app shuts down right after starting it, any ideas?
The second issue I have is pressing enter with my keyboard, it generates a "y" instead of a ENTER. My keyboard is recognized by the system, a Logitech K400.
Well, on the keyboard not much i can do since it seem its seems the system identifies it wrong maybe and assigns the wrong KL file, this is just what i think is happening.
On VPN i know about it, i still did not found a solution for it, even it it is at all from "my" side!
Que bueno Superceleron sigues activo!! hacia time que no pasaba poraqui y ahora que me han pasado un tanix x4 me puse a buscar y bingo!! rom tuya jejeje, thanks por tu curro
I have a Tanix S905X4 TV Box with slimBOXtv ATV version 11.21.1 I installed Browser For TV 1.42.2 which works perfectly.
But I can't open the browser from Youtube links through SmartTube Next because Android doesn't show Browser For TV 1.42.2 with a browser option. It only shows Chrome as an option.
Example: When I click on the link, the option to open with Browser For TV 1.42.2 does not appear (Photo 01) and shows (Photo 02)
Does anyone know how to make Browser For TV 1.42.2 appear as an option to open links (URL) on the Tanix S905X4 TV Box with slimBOXtv version 11.21.1?
Thanks!
This Thread is about Superceleron excellent work/Rom
For Tanix Box
