[ROM] Tanix X4 SC ATV v6.0 USERDEBUG - S905x4 - Android 11 - Multi-Wifi&BT
For some reason the box (Tanix x4 4gb 64gb) is not being detected in windows, when its starting it triggers a device recognition but after it enters recovery nothing shows up, i tried on 2 different pcs one with windows 11 and one with windows 10, i tried looking for more drivers but i found the same one its being installed by the tool
Originally posted by Goldman View Post
Thank you very much for replying!
I even tried on another computer but it didn't work. After a lot of searching I found a generic driver that worked and was able to burn the firmware as Amlogic USB Burning Tool v3.2.0. (if anyone needs the driver I'll post the link here)
It's working but with use it has errors (bugs) that it didn't have with the firmware that came with Tanix X4. I downloaded the firmware (Tanix_X4_s905x4-20220620) from more than 5 different locations but they are all exactly the same.
I noticed that my Tanix is the Tanix 4X PRO (see photo below). The firmware must have some difference from the version without PRO.
If anyone has a link to download the firmware, I would appreciate it!
(I found one on a Russian website but, not sure if it's the original image)
Also, is there a TWRP recovery for it? I would like to get a backup of the box.
Last question: How can I enable original "navigation bar" and "status bar"
Thank you.
Originally posted by edudez View Post
I have the same unit and looking for the original Firmware in case if I need to reinstall.
Thank you.
And dunno if anyone as a twrp backup.
And no you cant enable the navigation bar and status bar on the ATV build, if you want that use the "Normal" build that i also did!
well i do not have the original fw, you need to search it.
I wish there was a pure vanilla version of android OS for these tv-boxes.
How can I create my own fw? Are there any videos or any information/knowledge you can provide to get me started on?
Appreciate it.
Thank you for your response.
Appreciate it.
It all depends on what you want to do, if you a programmer and do not have afraid of biiiiggggggg projects then go for Linage OS (https://github.com/Amlogic-Lineage) or even AOSP!
Originally posted by xristos1925 View Post
Thank you! Is there any rom that I can install ? Also I have a CHOTT0102 S905X3. What rom can I install? Can I install the generic S905X3 Rom on this forum ?
thank very much
The s905x3 one yes you can try it but remember there is always a chance that might brick your device, so be warned!
on that s905x4 box i think you stuck on what you have!!
There are currently 1696 users online. 2 members and 1694 guests.
