[ROM] Tanix X4 SC ATV v6.0 USERDEBUG - S905x4 - Android 11 - Multi-Wifi&BT
Originally posted by soldiaz View PostYea weired Thing. Read there is New drivers for the x4 so I will try AML burning 3 later on
Issues with usb cable not inserted deep enough
Some had to trim/remove plastic so can insert deeper to make contact.
USB 3.18 or 3.20 is used/works on my HK1 X4
Hello,
I have spent two days trying to install this ROM, I'm not sure if anyone here can help.
I have tried using the Amlogic USB burn tool (versions 3.2.8, 3.2.0, and 3.1.8) and I am unable to get the box to interface with the burn tool:
- I tried holding the reset button (in spdif port), then inserting the usb in the blue usb port (closest to tf card reader), no success
- I tried holding the reset button (in spdif port), then inserting the usb in the black usb port (closest to power port, I suspect this is the otg port), no success
- I tried doing the above again, but this time connecting the power cord to it and then inserting the usb, no success
- I tried doing the above in a different usb port on my laptop (running windows 11 and a separate one running windows 10), no success
- I tried the Amlogic SD card burn tool and then inserting the sd card into the box, then powering it on, no success
I'm close to giving up, but I thought I'd ask if anyone here can share how they were able to install this rom. I have the 4GB RAM, 64 GB emmc version.
superceleron
1) Is there a 6.0 version for NORMAL (not ATV) build?
2) How to switch /system to read/write?
Originally posted by quincydog View Post
Hi, I think that the reset "Button" is in the AV port not SPDIF!
I'm certain I'm pressing the reset button, there's also no other port on my Tanix anyway (just usb, LAN port, etc).
There are currently 1637 users online. 2 members and 1635 guests.
