Well my first rom for a S905X4 device based on android 11.
Nothing from the STOCK rom was used, this is a clean build done from my own Amlogic Android 11 sdk.
Adicional note: On the 1º Boot when it shows the Pair remote screen, you can use it to pair any BT remote you might have, i added a bunch of KL configs for a few BT remotes.
But that does not mean it will support the one you going to pair.. so some keys functions might not work or do differently of what they supposed to do.
You guys can check the YT video on the bottom of this topic, showing the pair screen.
Changelog v6.0:
- Big update
- Added 1 more WiFichip (AP6256)
- Updated ALL WiFi and BT drivers to the latest builds i could get.
- Enabled generic Realtek Ethernet driver.
- Fixed root, it nows as the "normal" root(supersu), i will think in the future if i will add Magisk or not..
- Added root on/off switch, it on by default! (restart required to take effect, after each change)
- Added overlay that shows cpu speed/temp etc.. also network speed etc..
- Added option to choose the default UI for each app ( see app info page, only on side settings )
- Added Switch OS (if no usb stick or SDcard is present with other OS. it will boot to recovery)
- Added BT to TVSettings.
- Fixed lots of permissions.
- Fixed SPDIF output (i think... i do not have a way of testing it)
- Decided to do a OTA zip, use the included "update" app that is on the previous fw's (see bugs section is case something does not work ok after doing the OTA)
- And many other stuff...
Changelog v5.0:
- Small update
- Added DocumentsUI since it seems some emulators(and some filebrowser apps) need it to work correctly.
- Fixed access to "internal shared storage" (it was due to DocumentsUI be missing)
- Fixed some other permissions.
Changelog v4.0:
- Fixed Google assistant. (If you do the OTA then after it a Factory Reset is needed, if you don't do it the issue will continue there, this is only for V3, V1 and V2 are ok and no factory reset is needed)
- Added A95XF4 remote control.
Changelog v3.0:
- Fixed SDCARD detection
- Fixed front display ( Tanix X4 )
- Some small changes to the ETH to see if it becomes more stable
- Small change to the BT.
- Added support for EXT4 filesystem ( still in testing...)
- And some other minor stuff...
Changelog v2.0:
- Done OTA, it can be updated over the "Update" app on the fw.
- Removed Chromecast from the fw, since it will not work unless legit atv
- Added 2 apps that i think they are useful.
- Fixed Audio playback in Google Videos (and others)
- Added root (you wont get a pop up asking for permission, it will always give root to any app so... use legit apps!!!!)
- Now runs a bit more "cooler"!
Changelog v1.0:
- Build from latest AML R(11) SDK
- Multi Wifi & Multi BT.
- As true to ATV as possible.
- Bla bla bla...
- Bla bla bla bla...
- Bla bla bla bla bla...
- etc.... and many other stuff...
Still missing:
- TWRP.
- Of course there is bugs!! there always be bugs!!
- In case you have some weird issues with Google assistant after the ota, just go to "settings/device preferences/Google assistant" and disable it and then enable it or press the MIC button on your remote, that will enable it again and ask you a few questions. If the issue persists i recommend doing a factory reset.
- Also if you get a black screen after doing the ota... the only solution here is to reflash the img... sorry!
Want to buy me a beer?
Download:
Install instructions:
THIS ROM DELETES ALL YOUR DATA SO DO A BACKUP!
USE AT YOUR OWN RISK!
Enjoy it!
