[ROM] Tanix X4 SC ATV v6.0 USERDEBUG - S905x4 - Android 11 - Multi-Wifi&BT
I have Tanix 4X - S905X4, I downloaded Amlogic USB Burning Tool v3.2.0 and installed it on a computer running Windows 10 x64 but the installed drivers are not compatible with the Amlogic S905X4 as the computer does not recognize the TV Box (there is a question mark in the Windows device manager as if the USB driver is missing). I know how to do the procedure, because I've done firmware recording (flash) on a TV Box with Amlogic S905X3 using Windows 10 without problems. Please, can someone help me by pointing out where I can get the correct USB S905X4 driver for Windows 10? Thanks
Originally posted by Goldman View PostI have Tanix 4X - S905X4, I downloaded Amlogic USB Burning Tool v3.2.0 and installed it on a computer running Windows 10 x64 but the installed drivers are not compatible with the Amlogic S905X4 as the computer does not recognize the TV Box (there is a question mark in the Windows device manager as if the USB driver is missing). I know how to do the procedure, because I've done firmware recording (flash) on a TV Box with Amlogic S905X3 using Windows 10 without problems. Please, can someone help me by pointing out where I can get the correct USB S905X4 driver for Windows 10? Thanks
If you haven't already
Uninstall all versions of UBT and there drivers from all
Even delete desktop shortcut
Restart
Now install UBT 3.20.
Happy Testing
Try this maybe
Restart
Happy Testing
I even tried on another computer but it didn't work. After a lot of searching I found a generic driver that worked and was able to burn the firmware as Amlogic USB Burning Tool v3.2.0. (if anyone needs the driver I'll post the link here)
It's working but with use it has errors (bugs) that it didn't have with the firmware that came with Tanix X4. I downloaded the firmware (Tanix_X4_s905x4-20220620) from more than 5 different locations but they are all exactly the same.
I noticed that my Tanix is the Tanix 4X PRO (see photo below). The firmware must have some difference from the version without PRO.
If anyone has a link to download the firmware, I would appreciate it!
Thank you very much for replying!
Boot to recovery (toothpick method)
Factory data reset
let system reload
Sometimes can clear issues.
Go back to page 7 in this thread and read forward in time
There was firmware change
Something about wifi...
Also if you are happy with Factory Firmware
Then use it
Happy Testing
Originally posted by freddy View Post
Glad you have success!!!
Factory data reset
let system reload
Then use it
Happy Testing
There are currently 1969 users online. 0 members and 1969 guests.
