[ROM] Tanix X4 SC ATV v6.0 USERDEBUG - S905x4 - Android 11 - Multi-Wifi&BT
Originally posted by MaxJumper View Post
Also you wont get any of that formats on a non certified device(Certified android), if you want all of that on a non certified device you need CoreElec.
In android11 that "sound choice" is not needed, it automatically does it.
standard working. I tried CoreELEC, and I didn't get wi-fi and bluetooth on the A95x f4. Well, in general, KODI is inferior to android in terms of functionality, which I use. So I will continue to follow the topic, wait and hope that someday there will be a firmware that will satisfy me 100%. Thank you that this is possible thanks to your efforts.
I don't need all the surround sound formats, I'll be happy if I have the standard AC3 5.1
Originally posted by Ghost0159 View PostHello, I bought the box Android S1 max of bqeel being under the soc s905x4
I have installed your custom rom, but I have two small problems.
On the movies of canal+, the sound does not work.
And I also have the Netflix application that does not work.
Thanks in advance
On canal+ it depends on what audio is using, if its Dolby Digital 5.1/7.1 etc.. then it will not work.(Disney+ also as this issue)
Netflix are you using the app included in the rom? when i did v6.0 i tested and was working ok, if you install the one from ATV playstore that one will not work!
Someone here had a problem with DTS sound, etc. I have unchecked all options: Dolby drc Mode Off DTS DRC Mode 0 Associate Audio=Off HDMI output=Off if you have a receiver, then with these settings you will have DTS sound etc in Kodi. However, I do not have DTS-HD and TrueHD sound. Kodi converts DTS-HD audio to normal DTS audio. I think there is a Kodi problem. I'm using version 19.4, maybe the next version will fix these problems. Maybe you need to check other video apps. But I have another problem how to connect the speakers with a 3.5 mini jack stereo cable with SPDIF to the RCA output (1 white cable, the other red). I tried to connect the speakers with a cable with a 3.5 mm stereo mini jack to the amplifier to RCA and there is no sound in the speakers
Hi, well i do no have that device so i cant really tell where is the problem, remember this was done for the Tanix x4 and i only tested on that device.
Originally posted by WupiWuki View PostSomeone here had a problem with DTS sound, etc. I have unchecked all options: Dolby drc Mode Off DTS DRC Mode 0 Associate Audio=Off HDMI output=Off if you have a receiver, then with these settings you will have DTS sound etc in Kodi. However, I do not have DTS-HD and TrueHD sound. Kodi converts DTS-HD audio to normal DTS audio. I think there is a Kodi problem. I'm using version 19.4, maybe the next version will fix these problems. Maybe you need to check other video apps. But I have another problem how to connect the speakers with a 3.5 mini jack stereo cable with SPDIF to the RCA output (1 white cable, the other red). I tried to connect the speakers with a cable with a 3.5 mm stereo mini jack to the amplifier to RCA and there is no sound in the speakers
So I managed to get the sound to work on canal+, but Netflix doesn't work at all, although I use the one that is included. In addition it is the mobile version and not the tv version
Convertidor de Audio Digital a analógico, Coaxial/fibra óptica a Caja analógica Digital a analógica| | - AliExpress
Connect Tanix X4 cable to SPDIF DAC
Cable de Audio y vídeo AV Jack a 3 RCA macho de 3,5mm, Cable estéreo auxiliar, convertidor estándar para altavoz 3RCA, TV Box, CD, reproductor de DVD, 1,5 M| | - AliExpress
You must connect white RCA Cable to the DAC
Audio Quality is much better than BT AudioEnjoy
Glad the system is updated. I use this device as a replacement for a large PC on a 21 inch monitor. But there are still problems which I will describe below:
- I'm using beta 6.0 from this thread
- The device is Tanix x4 4GB RAM and 64GB storage
1. The undo option (back arrow) on the remote control does not work
2. Why are there still Exoplayer and Movieplayer installed as default? Kodi is the best video player and should be installed by default. Possibly VLC
3. Microsoft SwiftKey is a better virtual keyboard than gboard and should be installed by default
4. I checked all browsers on this device how they work and Opera works best of all. It should be installed by default
5. Total Commander is the best file manager for Android. It should be installed by default. The default file managers from the beta version of the system do not allow you to delete files
6. A program should be installed that displays virtual icons for undo, homepage and desktop lock. The best is the Navigation Bar
7. The Updater option does not work. Spent 2 days before I was able to upload new firmware from version 4.0 to 6.0 Upgrading to future versions should be easier
8. The option of selecting the UI in the programs does not affect them in any way. The UI hasn't changed in any of the programs I've checked
Originally posted by WupiWuki View PostGlad the system is updated. I use this device as a replacement for a large PC on a 21 inch monitor. But there are still problems which I will describe below:
But i will take care of 2 (will add vlc) and 5(will add total commander, since is the best one for me.. i forgot to change it), 7 weird it works just fine for me, and all other check Normal version
Anyway thks for the report
Originally posted by musgo View Post
I bought this device (DAC) to get SPDIF audio to analog
There are currently 2577 users online. 1 members and 2576 guests.
