[ROM] Tanix X4 SC ATV v6.0 USERDEBUG - S905x4 - Android 11 - Multi-Wifi&BT
I tried your image on an X96 X4.
Strangely neither USB nor SD update did work but after a few tries I got the USB burn tool working.
The front display won't work (doesn't really matter) but also the remote isn't working properly. Going down the list works, going up doesn't. I found another key for up but couldn't find any for OK, so I cannot complete the setup wizard. Hopefully this will be fixed in a later release. I would really like to use this image.
Originally posted by superceleron View PostDISCLAIMER: MY ROMs(WORK) CAN NOT BUT USED FOR ANY COMMERCIAL PROJECTS WITHOUT MY CONSENT.
Well my first rom for a S905X4 device based on android 11.
Nothing from the STOCK rom was used, this is a clean build done from my own Amlogic Android 11 sdk.Last edited by superceleron; 21 June 2022, 10:38.
Now, the box runs awesome with the ROM. I will post some pictures and videos later.
superceleron : if you can fix this issue, please help. Thank you.
well its hard to support all remotes guys, i know it frustrating since i made this build only for the TX4.
I do not have another s905x4 device with me now, since company's simple stop sending me samples so i'm limited + i'm also limited on time i have to work on this!
I will try to see what i can do, but no promises..
Originally posted by superceleron View Postwell its hard to support all remotes guys, i know it frustrating since i made this build only for the TX4.
This is the latest update for the X96 X4:
One other suggestion: Could the front-display be used to display the play time? I don't need it as a clock but play time would be useful.
Thanks for your work anyways. I'm sure this can be solved. Maybe the extraction of the code from the manufacturer image is possible.
Originally posted by Gabbano View PostHi. So far atv version works pretty well with my tanix x4 ❤️ Does it support dolby sound? Because im missing the sound on Disney +. Can you help ?
There are currently 2293 users online. 0 members and 2293 guests.
