[ROM] Tanix X4 SC ATV v6.0 USERDEBUG - S905x4 - Android 11 - Multi-Wifi&BT
Originally posted by powderlinux View PostHey. Awesome job on this rom! I was wondering if it is possible to make it so that we can change the front clock from 24 hr to 12 hr format? I was able to do it on the default rom through the Android settings, but it just stays on 24 hr on the custom rom.. Thanks.
I installed the rom because the bluetooth doesn't work well on stock rom.
I have a remote/keyboard that works perfectly with all devices, except Tanix. I also bought another remote, with an air mouse option (the first mentioned one has the same), but the cursor chops, the remote disconnects, then reconnects. I have a Raspberry pi 4, on which I installed KonstaKang android, and even there it works perfectly.
What is the problem with the Tanix android device?Last edited by gavranpero; 13 October 2022, 14:14.
Originally posted by gavranpero View PostI installed the rom because the bluetooth doesn't work well on stock rom.
I think is a driver issue, but who knows... i reported to my contacts in the factory a few months a go i did not ear anything of them since!
So my recommendation is finding a fw where it works ok(or kind of ok...)
There are currently 1940 users online. 0 members and 1940 guests.
