RK3229_SS6051P - ATV9 - TechLife Rom
    Hi I l have added you to Telegram. But I couldn't send you a message.
      I didn't understand ! Why can't you send messages on Telegram?
        Send me the QR code of your Telegram account and I'll add you ok
          Originally posted by freddy View Post
          Hmmmmmm
          Have not tested rockchip since before Pandemic
          Will try to dig out old Schisson V88 from dust collection box.
          Happy Testing
          Okay
          Dusted her off..
          First attempt with Batch Tool 1.8 / driver assist 4.1.1
          Soft brick/stuck on Boot Image
          Second attempt with updated driver assist 5.1.1
          Same results
          Had to use maskrom to flash Leelbox 7.12 to recover.
          So decided to try Factory Tool(Release Version) v1.64
          Success!!!!
          This old 1/8 still chuging along.
          Thanks for Rom!!!
            Okay
            Dusted her off..
            Same results
            Success!!!!
            Thanks for Rom!!!
            Enjoy Your new Schisson V88 ATV9. Please report possible bugs to me. To make improvements in the next versions ! Thanks!
              maybe there is a new version?
                ATV10 RK3229/RK3228a. Two versions of WI-FI chip RK912 and RK915a
                https://forum.freaktab.com/node/833256
                  I tried to install it with flashtool 1.66 and 1.64. When I install it, it starts to install again in Flashtool, I have to pull out cable for it to stop. In both cases, I leave it and it shows only TECHLIFE ATV ROM, and it's stuck on that after 10 minutes. Other RK3229 rom works.. board is RK322X and SS6051 (without P)
                  version 1.0 works tho... (with 1.64) Wifi does not work, maybe it's because my wifi in Device INFO hw was sv6158? Can I fix this? i have old original firmware
                    Do you want to learn how to edit firmwares? I can teach you some knowledge
                    Hello, best regards for you. I installed the ATV10 version on my TV box and it works very nice but it only has one detail. The box originally comes with 128Gb of storage and only recognizes less 4Gb. I would like to know if I can fix that somehow. I would like to learn. I appreciate a lot your help.
                      Do you have rk3229 atv10 with ssv6051 driver
                        Hello friend. My box have rk3229 with sv6256p(wifi). The ATV10 it's work nice. So' my situation it's now recognize less 4Gb storage .
                          Hi, do you have rk3229/3228a ATV10 OR ATV11 WITH THE DRIVER OF WIFI SSV6051?
                            Hello, good afternoon, I have a rk3229 tv box with SS6051 wifi, it works well except for the wifi, it doesn't work for me.
                            Is there any solution?​
