We have finished but while I can flash this and make sure it is not a BRICK ROM, we cannot test the features. Please read the README FIRST.txt file in the ROM kit for features and how to use the ROM and APP Injector.
Please test and report the following:
1) Overall ROM Performance and Stability
2) Petrus' App Injector. Did it work and find the package.zip? Did it inject apps properly? Did they work?
3) REMOVED FOR BETA test rev a. - Miklaus' updated settings.apk. Please try to test all the menus in settings. Let us know what should be removed or things that cause a force close that should work. Your feedback here gives you a better settings menu!
4) The WPA supplicant. Does it work like before and give you adhoc?
5) Please try not to report busg that are in the stock ROM. There is not much we can do about them at this time.
NOTE: This is built from the stock #1011 ROM.
UPDATE April 19 2012. BETA test version REV a was a bust. Rev b had some appp issues because I used the NB 1211 APKs. NEW test version is c. File download name has been updated.
Here is the download link:
ROM -> Nextbook 7 Premium #1011 Finless 1.5 ROM - BETA TEST Rev d (178 megs)
Thanks for testing!
