Android 13 ATV AMLOGIC S912 (Lineage OS 20) LPDDR3
Originally posted by bumerc View Postsave as text file and attach here, or pastebin link
I use Kitty(windows friendly)
Automatically saves to desktop.
Can use notepad++ to convert as txt.
No permissions from site
I don't have pastebin
Its not worth the effort
Have no working HDMI
At best i could confirm it boots works
Others here with working HDMI would benefit
You may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
Originally posted by soldiaz View PostDear bumerc I flashed HighwayStar 's image and it boots up on Vorke LPDDR3 device.
Unfortunately I cant pass setup since wifi drivers are missing. Vorke uses qca9377 wifi / BT combo. If you could supply proper vendor would be awesome and I will continue testing
So far 2 suggestions:
- guess would be good to remove setup assistant 1st step (need to press back + home)
- lower USB port without function only 1 port working
+ reset button still working !
For H96pro+ 3/32 set-top boxes
Fixed Wi-Fi - BT issue
Revision support:
CZ-S32-V5 (LPDDR3) 3g
CZ-S32-V6 (LPDDR3) 3g
CZ-S32-V6.1 (LPDDR3) 3g
WiFi-BT - HS2834A (QCA9377)
1000M eth
Wi-Fi, BT, LAN, USB ports, native remote control, complete shutdown of LEDs in hibernation mode, on. - blue, sleep - red.
download
Firmware based on LOS-19.1 ATV12 + gapps
Revision support:
1000M eth
download
Originally posted by soldiaz View PostJust flashed, not working on VORKE S912, fortunately box still enters flash mode so I will return to Android 9 build and test either HDMI output isnt working or build which isnt working with that unit ;-)
Originally posted by bumerc View Postsoldiaz
As promised, TX92 build.
Brief information and notes - CPU S912
- Platforn GXM, Q200
- RAM LPDDR3, capacity - 3G
- ETH 1000Mbit
- Wi-Fi/BT QCA9377
Build is only suitable for lpddr3/3g devices and has not been tested by me. Gapps are integrated. Ir-remote debug is activated by default in the driver, you can now take the key codes from the dmesg or from the logcat. Happy testing :-)
Download
You built this one in the past and after few attempts it booted but had now wifi and no bt, ethernet worked
No Bluetooth to what extent? Is bt mac visible in the settings? Do the other BT devices see your box when scanning? I could optimize a few more settings of the bt stack and possibly add some overlays for the bt app. Logcat would be appropriate here
Hi
I grabbed Higwaystar's build and try wether HDMI port is damaged and wether thats the reason for failing
There are currently 1456 users online. 1 members and 1455 guests.
