Android 13 ATV AMLOGIC S912 (Lineage OS 20) LPDDR3
Just on other note, I have switched to your builds and the bluetooth work but refuses to identify MI remote, I am using a app to manully pair the remote however after every reboot the connection is lost and I have to redo the entire process again.
Another question : is the IR working, I was wondering if the original remote cfg would work if I manually add it.
Originally posted by ppromo47 View Post
Thank you for all your effort, I dont have skills or powerfull PC to be able to do this , I will live without it ...
The rom is stuck on boot logo, I can use customisation tool unpack this rom and manuly paste into working ROM, but I dont know which specific file to look for.
can you help which files should I transfer?
Originally posted by bumerc View Post
Which ROM works on your device? Send me the link. I will implement it there
Firmware based on LOS-19.1 ATV12 + gapps
For H96pro+ 3/32 set-top boxes
Fixed Wi-Fi - BT issue
Revision support:
CZ-S32-V5 (LPDDR3) 3g
CZ-S32-V6 (LPDDR3) 3g
CZ-S32-V6.1 (LPDDR3) 3g
WiFi-BT - HS2834A (QCA9377)
1000M eth
Wi-Fi, BT, LAN, USB ports, native remote control, complete shutdown of LEDs in hibernation mode, on. - blue, sleep - red.
download
Your link mentioned above works fine.
LOS 20 by HighwayStar also boots fine but WIFI and Bluetooth is broken.Last edited by ppromo47; 14 September 2024, 13:02.
lineage-19.1-20240118-UNOFFICIAL-h96pro.tar.xz
https://drive.google.com/file/d/13ys...w?usp=drivesdk
Originally posted by soldiaz View PostThis is what - I guess - is running on my vorke. I dont need display so it is fine for me
So currently I am using LOS 20 by HighwayStar since for me bluetooth is as good as unstable in both builds (los 19 by bumerc) , will wait for a fix.Last edited by ppromo47; 19 September 2024, 06:13.
The Vorke Z6 Plus is essentially the same as the TX92, so it should function properly as long as it’s using LPDDR. Getting the front display to work would be a bonus. I’m currently waiting for a fix for the Bluetooth and IR remote issues. In the current setup, I can’t connect to the Mi Remote through the remote accessories settings. Instead, I’m using a third-party app to pair and connect the remote, but I have to repeat the entire process after every reboot.
There are currently 1830 users online. 0 members and 1830 guests.
