Android 13 ATV AMLOGIC S912 (Lineage OS 20) LPDDR3
I flashed HighwayStar build and could have been my fault maybe the hdmi cable wasnt connected properly. Ill reflash your build and check everything again
Originally posted by bumerc View Post
Firmware based on LOS-19.1 ATV12 + gapps
For H96pro+ 3/32 set-top boxes
Fixed Wi-Fi - BT issue
Revision support:
CZ-S32-V5 (LPDDR3) 3g
CZ-S32-V6 (LPDDR3) 3g
CZ-S32-V6.1 (LPDDR3) 3g
WiFi-BT - HS2834A (QCA9377)
1000M eth
Wi-Fi, BT, LAN, USB ports, native remote control, complete shutdown of LEDs in hibernation mode, on. - blue, sleep - red.
download
- S912 processor
- 16GB eMMC storage
- 2GB DDR3 RAM
Originally posted by soldiaz View PostThought could be a good idea to open new thread for devices using LPDDR3 like TX92, Vontar, H96+ pro....
Thanks bumerc for the hint!
Micron D9TXF >> MT52L768M32D3PU-107 WT:B (part number) max 933MHZ, LPDDR3
Build by HighwayStar :
Thank you sharing this ROM, its much stable except for the bluetooth and WIFI, I have flashed it on my device Tanix tx92 [s912 LPRAM 3/32 QCA9377], will it be possible to provide a patch to get Bluetooth, WIFI and front LED working?
For now this since this is my secondary TV I am ok to use ny phone as remote control and it works perfectly fine
Originally posted by ppromo47 View Post
HighwayStar bumerc
For vfd display you need a vfd driver, vfdservice daemon, corresponding dtb node, an entry in the *.rc file to run the daemon, sepolicy rules vfd_service_exec etc. and corresponding file_contexts entry (all these things are not included in this build). I use the openvfd driver + YAopenvfD daemon on my x96x9 device, works fine so far.
No, it's a regular binary file.
is there a readme or tutorial on how you got it working.
I am inclined at using A13 hence I wanted to check if there is patch for WIFI and Bluetooth which can be flashed on LOS20Last edited by ppromo47; 30 August 2024, 11:30.
Ok I tried YAopenvfD from the link below, however when I run the command to check "modinfo openvfd" or "ls /proc/device-tree/openvfd" both says not found.
You have to compile the driver and the daemon first. In A13 the bt stack was changed, there were problems with the hci interface. I haven't followed up on how it was fixed, but I couldn't use libbt-vendor for qca bt in los20. Patches are only on my PC, I didn't have time to put it on github. A guide would be too extensive, no time for that, maybe later
There are currently 2303 users online. 1 members and 2302 guests.
