Amlogic Next7HD8G (NX007HD8G) Modified Recovery - Stock Rom & Flashable Root
    Originally posted by DaremoS View Post
    I've seen many roms for AML8726-MX for Ainol made by Christian Troy.
    Are some of them portable to AML8726-MXS?
    BTW... what's the difference?
    I'm interested specially in his CM11 (4.4.2) mine is infamous NX007HD8G.
    Does this has SElinux kernel?
    Maybe I've should ask for this in Troy site, but mine is Yifang / Nextbook stuff.
    TIA
    They are portable... but it isn't simple...
    Requires using the stock Nextbook kernel, changes to the boot image, and lots of changes to the ROM to get all the hardware working.
    I've been trying to build from source using CT's device tree, but I haven't been able to get everything working yet. I've temporarily given up in order to focus on getting some more stock based ROMs released.
    ShaunMT
    Freaktab Rom Developer
      HI i need help
      HI I HAD MY [NEXTBOOK 7HD8G] FOR 1 YEAR NOW AND NEVER WAS ABLE TO FLASH ANY ZIP FILE.
      TODAY I WAS SEARCHING ON HOW TO FLASH ZIP FILES AND IT BROUGHT ME TO UR LINK.
      SO NOW I KNOW ITS POSSIBLE TO FLASH NOW THANKS TO YOU I CAN NOW BE ABLE TO.BUT I TRIED YOUR INSTRUCTIONS AND IT DIDN,T WORK THIS IS WHAT I DID:
      [I DOWWNLOADED THE ZIP FILE AND EXTRACTED IT TO MY EXTERNAL SDCARD AND INSURTED IT AND REBOOTED INTO RECOVERY]BUT WHEN I WENT INTO RECOVERY I SAW THE SAME OLD MENUS,NOTHING TO BE ABLE TO FLASH ZIP FILES
      CAN YOU PLEASE LEAVE SPISIFIC INSTRUCTIONS ON WHAT TO DO PLEASE OR ANYONE IN THE COMMENTS THAT GOT TRUE WITH IT
        First: That recovery was supposed to look exactly like the stock recovery, however it checked for Google test signature keys instead of the private Nextbook update signature keys that the stock recovery used.
        Second: The file was obsolete and I have removed the download link. Use TWRP recovery from here instead: http://www.freaktab.com/showthread.php?12618-TWRP-Recovery-with-UBIFS-Support-For-Amlogic-Nextbook-Tablets-(Download-Thread)
        Be sure to download the correct version for your tablet.
        ShaunMT
          Freeze on my tablet
          Hi! I have a Next 7hd8gb ,buy in Romania on different name (Evolio Evotab Hd),and is getting stuck on logo.I"ve wipe cache,partition but that not solve the problem. Then i install the stock rom taht is posted here ,all good ,installed ok ,everything works good ,but is getting hot and freezing,artifacts,and need restarting.The freezing is quite often.Please help me.
            In my experience with this model and several similar models, overheating is common. It is almost impossible to play most games without overheating them to the point of a forced shutdown.
            ShaunMT
              Yes i understand,but with the original stock rom from Evolio(seller) this problem was absent.Now the freeze is very often whithout playing games.What can i do ,how can i optimize the rom? Please help me because the seller don"t share the rom,and now i can"t send to them.Thank you.
                The stock ROM was probably further underclocked to prevent overheating by slowing the CPU
                If you have root access, you might be able to use an app like SetCPU or No Frills CPU to change the governor / clock speeds to make the tablet slower but cooler and more stable.
                ShaunMT
                  Hard bricked tablet
                  Hi Shaunmt! Please help me to unbrick my nx007hd8gb tablet.I tried some roms from other tablet (elf2,onda v711d)and of course they not work ,installed back the nextbook rom,work a little time ,freeze like i told you earlyear in this thread ,stopped by power button and the tablet wont wakeup ,but is recognize in amlogic burning tool. Please help me because is not mine!
                    DO NOT ATTEMPT TO USE THE AMLOGIC BURNING TOOL!
                    We DO NOT have the necessary files to use the Amlogic burning tool with your tablet... without them, the only thing you can do is low level format the entire nand chip, completing erasing the internal memory, partition layouts and all! DO NOT DO THIS!
                    Are you still able to boot into TWRP from external SD card?
                    If not, you're going to need a bootable rescue SD card, and I haven't made one for your model yet.
                    ShaunMT
                      Nope ,i"m not able to boot on TWRP.You have in plan to make a rescue sd card for this tablet?
                        I'll add it to my to do list...
                          ok,thank you.
                            Hi shaunmt! I want to tell you that i got a backup rom for my tablet evolio evotab hd (nx007hd8gb) http://www.mediafire.com/download/n8...votabHD_BKP.7z from another romanian user ,but i can"t do nothing with that because i can"t boot at all.Maybe you will do the rescue sd for nx007hd.Please and thank you!!!Have a nice day!
                              I downloaded a copy of your ROM, but I probably won't have time to look at it for awhile...
                              ShaunMT
                                Can you tell me what is that lcd test?Click image for larger version
