ShaunMT
Amlogic Next7HD8G (NX007HD8G) Modified Recovery - Stock Rom & Flashable Root
Originally posted by dorud82 View Post
ShaunMTFreaktab Rom Developer
Originally posted by dorud82 View PostHi Shaunmt! Please help me with the recovery sdcard for NX007HD8gb.I tried the NX008HD recovery sd card but only this i got.[ATTACH=CONFIG]7989[/ATTACH].Please help me! Have a nice day!
If I recall.... I think the 7 and 8 inch have the same bootloader...
Reformat your micro sd card (switch to a normal non "rescue" one) and try TWRP again. If it boots TWRP, you should be good to flash.
Originally posted by dorud82 View PostIt"s not working .Why?What can be wrong?
Are you sure you used the correct unbrick kit?
Originally posted by dorud82 View PostAre you sure you used the correct unbrick kit?
ShaunMT
Are you trying to use those on the NX007HD8G?
Originally posted by dorud82 View PostIt would be great if you do.Maybe you can look at the backup that i post in this thread. Thank you and have a nice day!!
Guest
silly newbie
Hi, I'm only new here and new to rooting (not real life rooting though lol)
I have located the download (locked post) about the flashable zip to root my NEXTBOOK NX007HD8G 7" tablet
Actual reported model number: YIFANG: EBM7000NBD
CPU model: ARMv7 Processor rev 0 (v71)
CPU Frequency: 1512 mhz (Dual core)
Screen Res.: 1024 x 552
Pixel density: 160 Dpi
Bluetooth: Unavailable
Wifi: Enabled
GPS: Disabled
Android version: 4.1.1
Kernel version:
3.0.8-gfd02cf8
xn@xn-desktop #306
SMP PREEMPT Thu Sep 12 16:49:19 CST 2013
Build number:
(System build number): V1.0.2.JR003C.user.root20130912
BUT the instruction says to flash it using the modified recovery above, and the recovery has been removed?
Below is what it says:
Root Package:
This is a flashable .zip that installs the su binary and has been signed with Google Test Keys.
Put it on your external SD Card and flash it using the modified recovery above. Then install your preference of Superuser.apk or SuperSu.apk from the Google Play store or elsewhere.
Download: http://www.freak-tab.de/ShaunMT/Kyser_Root-signed.zip
Originally posted by gasgrassorarse View PostHi, I'm only new here and new to rooting (not real life rooting though lol)
Wifi: Enabled
GPS: Disabled
Kernel version:
3.0.8-gfd02cf8
xn@xn-desktop #306
Build number:
Root Package:
Sorry... I need to make a new page for the Kyser_Root package...
The modified recovery referenced in the post you quoted was replaced by TWRP recovery:
http://www.freaktab.com/showthread.php?12618-TWRP-Recovery-with-UBIFS-Support-For-Amlogic-Nextbook-Tablets-(Download-Thread)
You can flash the Kyser_Root-signed.zip with the appropriate TWRP for your model from that page.
I also need to release a pre-rooted modified ROM for that model, which I have not done yet. I might get to it soon...
Guest
Originally posted by shaunmt View PostSorry... I need to make a new page for the Kyser_Root package...
ShaunMT
As I said, I'm only new to android and flashing etc but I guess I just download and install the suitable TWRP first.
If my ROM? was suitable and I had any idea how to do it I would
There are currently 1777 users online. 3 members and 1774 guests.
