Minix Neo X7 - Finless 1.7 ROM
    rooting software
    Originally posted by benster1 View Post
    Doesnt work... With first 007 didnt work also..
    Big Benster
    That is the software I used today to root my neo x7 with finless 1.7 fw. It had to root b/c then I copied the Strasburg passthrough patch and pasted it after extracting it. I took root explorer to mount the drive as readable and writable . With patience it should work. Good Luck!
      Re: NEW - Minix Neo X7 - Finless 1.7 ROM
      Why do you root finless 1.7? Its pre rooted...
      Big Benster
        bob are you going to update with the new sources1.7 fw?
          Big Benster
          Good question... lol
          I think few confusions about root here
            Nice job bob.. My congratulations for your efforts . Very nice and smooth rom..
            The only issue I have found is on cpuz shows me all four cores stuck at 816khz and not even close on 1.8mhz.. I flashed it with oc kernel 1. 8 and 800 ddr.
              Originally posted by Ravendark View Post
              it does, I rooted it yesterday
              Well show me... Every comment under that tread states that it doesnt work since 007. Even bob says it..
              Big Benster
                Big Benster
                Now that you mention it... I run Kingo app before that and I thought that although it said device rooted...it didn't do anything...then I did that method with moborobo, it failed twice but it said rooted in the third attempt...
                Could be you are right and kingo did the job afterall...
                But now the box is definitely rooted.
                  Well it says root /0 so lets check it out.
                  Big Benster
                    Big Benster
                    Big Benster
                      Big Benster
                      it did on the third attempt and installed all the software...
                        First attempt worked right away!!!
                        Officialy been pimpedd....
                        Big Benster
                          Big Benster
                          Thanks ravendark... I tought it didnt work but it does.
                          Now sixaxis check for bob brb
                          Big Benster
                            Sixaxis controller app doesnt work...
                            Big Benster
                              Big Benster
                              Shit.
                                Big Benster
                                no bother mate!
