Mask ROM mode MK802IV (need help)
Originally posted by Crusader2003 View PostYes I tried.
After idb reset I get Flash info fail.
Still get error [ATTACH=CONFIG]4094[/ATTACH]
If I try again I get a download error.
I had similar problem and it solved when I used ports on back of PC (e.g directly connected to MB).
Also make sure you click restore, not upgrade!
Return for warrenty
I tried every thing.
My device was booting directly into maskrom mode without pressing the reset buton.
Tried other cables other pc other usb ports, other hdmi port.
Tried shorting port 8 and 9.
Nothing worked.
I have send back the item to geekbuying and now im getting a new one.
Everyone thanks for trying to help
There are currently 2023 users online. 2 members and 2021 guests.
