SPMC
Ouch, yes i hope he continues is work ok SPMC!
So SPMC "Jarvis" will most probably be a realityTronsmart "Prometheus" VS-ATV-106
Dualcore 8726-M6 @ 1.5GHz - 1GB RAM 8GB iSD
Finless ROM 1.3 - Android 4.2.2
XBMC v13 RC1
Originally posted by prahjister View Post
BOOM .....I hadn't read that but read it into it from some posts that is the way it was. Rockchip better step up the mediacodec compatibility or they will be left in the dust. My r89 still just sits there and i will play with occasionally when a rom looks ok....Amlogic seems like it is definitely the way to go. I hope the do good with s905. My MK808B plus is fantastic with official Kodi now.
Getting a shield for xmas from the parents...So exited.
If you don't mind kitkat, have you tried mo123's v1.7 ROM? It features:
"Stutter-free playback in SPMC
Latest apps
10-bit color support for 4K videos
23.976 framerate videos play better
updated ffmpeg
4096 resolution videos play correctly
Some ui display optimization
Solve the problem with can't play certain video games
Increase CPU speed"
Antutu scores should be close to 40K!
I know that it's for the Nagrace, but believe me mo's ROMs are the best ones available for the R89, too!
I haven't tried his newest Lollipop ROMs because they may be less stable than the kitkat. Still, you can see from the posts on his lollipop threads, he is making great progess.
I hope this helps you get some more use out of that R89!
Cheers!
-SB---------------------------------------
Currently using U-BOX R89 with mo123 v1.6.
Other android tv device - ADT-1 running latest PureNexus 6.0.1 MM and very impressed with the changes vs stock molly!
Pipo M9S -- CrewRKTab custom rooted 4.4.2
RCA Viking Pro 10 -- Custom stock rooted 5.1 by me <- FOR SALE
----------- ROM by me, the first way to update ZTE Force 4G from ICS to JB http://androidforums.com/threads/fin...om-ics.886408/
I haven't tried Wasser's latest ROM, and I do like some features of his past ROMs(i also have a great deal of personal respect for Wasser), but every time I've flashed one for testing I've gone back to mo123's ROMs!
Maybe it's my personal preference, but it always seems to me that mo always seems to have the best combination of performance and stability, hands down!
Cheers!
Originally posted by sawbones999 View PostI haven't tried Wasser's latest ROM, and I do like some features of his past ROMs(i also have a great deal of personal respect for Wasser), but every time I've flashed one for testing I've gone back to mo123's ROMs!
Cheers!
-SB
Thanks!
-AaronTronsmart R28 PRO with wasser-2.0.7-beelink-r89-rk3288 ROM and MX Player
Cheers!
-SB
Talking about balance between performance & stability I had found Hisound Ugoos - stage 3 (kitkat) for the R89 with the Resource Image from Gormar (cpu clock up to 1.92 Ghz) as the most solid attempt to get the most decent performance and better stability for this device.
Lollipop from wasser had bring a shinny and spectacular bright / colour depth to the picture on R89 but with lost of stability and strange hardware performance or better call it hardware problems like ethernet & Wifi Problems (dissapearing or lossing the connection) during the time.
For me SPMC 14.2 is still working fine but I like more the most recent Kodi 16 beta 5 or nightlies 16 RC1.
Hey everyone,
I'm a big fan of SPMC as it's less laggy on my my Matricom G-Box Midnight Q than Kodi. There is just one problem. I cannot change the view setting when I playback any video and while it's fine for videos with 1.77:1 or 1.85:1 it's fine with the widescreen TV I have. However if the video is 4:3 or say 2.35:1 it stretches the picture out without black bars. I have tried going through the view mode setting but the settings don't change. I also tried using my wireless keyboard and trying to use the Z button but each type I try it, same result. It stays at the same size.
I have included a couple of screenshots to show the difference. The one with black bars is when I play it in Kodi.while the other is with SPMC playing. Both are the default view modes but as I said cannot change the SPMC setting.
The Kodi version is 15.2 and SPMC is 13.4.0
Any help would be much appreciatedYou may only view thumbnails in this gallery. This gallery has 2 photos.2 Photos
You can also disable hardware acceleration settings so videos play with the CPU.
You will then have options to change the view/zoom mode with the video icon while a video is playing.
- Using Hardware Acceleration, all the video settings are disabled (Zoom, pixel, brightness etc) are all unchangeable.
- I tried the software route but the video still had issues with picture size. I was able to change it but normal size still required some tinkering with the zoom aspect. The video was also a bit laggy but it was an option.
Thanks!
You can see the progress that Koying is making here: https://github.com/koying?tab=activity From what I can tell he's working on SPMC JarvisTronsmart R28 PRO with wasser-2.0.7-beelink-r89-rk3288 ROM and MX Player
You can probably download it here when he's done. https://github.com/koying/SPMC/releasesTronsmart R28 PRO with wasser-2.0.7-beelink-r89-rk3288 ROM and MX Player
Originally posted by amclean123 View PostYou can probably download it here when he's done. https://github.com/koying/SPMC/releases
There are currently 1731 users online. 3 members and 1728 guests.
