Minix Neo X7 Quickshot Rom by The Nitro Team
v2 is coming...There are 10 types of people in the world: Those who understand binary, and those who don't...
If you want to buy me a beer, please use this -> https://www.paypalobjects.com/en_US/..._donate_SM.gif
Originally posted by gxaris View PostHi, just a stupid question: can i flash this firmware on Ugoos UT1? Is the hardware different?In the best case it will boot but you will not have wifi,bt, ethernet, etc...
Remote controller cannot pair
Thanks for the great ROM! It works well less one portion for me. While the stock remote works, there is no pointer on the screen and I have to scroll using the d-pad.
I tried to pair with the RII K25 Airmouse, but nothing seems to work. Can anyone help?
Thank you in advance!
Originally posted by djla View PostThanks for the great ROM! It works well less one portion for me. While the stock remote works, there is no pointer on the screen and I have to scroll using the d-pad.
want to install this program, looks like something our family really wants, bought unit with finless 1.8 already installed , I think I can use finless program to over write using quickshot rom correct ?
can i add beyond xbmc also at same time of flashing ?
how would I add both programs when writing to minix neo 7 also should backup and how .
sorry for the questions really first time do this type of programming here and don't want to make a bad error . want to thank all in advance ..
Originally posted by freeme2 View Postwant to install this program, looks like something our family really wants, bought unit with finless 1.8 already installed , I think I can use finless program to over write using quickshot rom correct ?
First... you want the latest version of Quickshot which is at the top of this forum area... v2. Since the finless version and the new Quickshot v2 could be using two different partition setups... follow the instructions they gave to flash it.
Beyond XMBC is an app that you install.... you don't flash it. You download it to your Neo x7 and run the APK file to install.
Backing up... The steps you take will depend on what is it exactly that you want backed up. There is the ROM which is the operating system and then there are the apps you have installed along with ( possibly ) the data. If it is just the ROM you are concerned with... just download another copy. If you want your apps you have installed later and/or the data... you need to use a program such as Titanium Backup and save the backups to an external SD card since all information, data and whatever that is on the internal partitions like the internal sdcard will be wiped when you flash another ROM.
There are currently 2440 users online. 0 members and 2440 guests.
