Help identify possible t r42?
    Originally posted by MattPaul View Post
    Yess it works! Ok the Loader was the problem
    Cool! We need someone to modify the kernel now to 1080p and overclock it. Nice heatsink push it to 1.9ghz and around 19,000 antutu score!! Levy we need your help with this kernel , Prosze!
      Originally posted by BART_TECH View Post
      That's what I thought.
      You need to flash from original rom,
      LOADER
      PARAMETER
      MISC
      KERNEL
      BOOT
      RECOVERY
      SYSTEM------------>FROM WASSER'S ROM
      BACKUP
      That will work fine.
      I just downloaded the wasser-FW, the stock boot.img and the stock kernel.img to flash my T-r42, but how do I flash the Stock Loader, Parameter, Misc, Kernel, boot, recovery and Backup?
      You said I take all these from the original firmware and only the System.img from wasser...
      So I'm a bit confused how to do it
      Have someone already tried to get Picuntu/Linux or other custom Android-ROMs running on the cs918?
      edit:
      When I flash the box with "RK Batch tool" and the stock-fw, and afterwards only the wasser-system.img with the rk flash tool, the box still boots up on Stock-FW as I didnt put on the wasser-system...
        Could someone pls reupload the wasser-firmware 1.2.4 for t-r42?
        1.2.5 doesn't work for me...
        the link on this page is down!
          @kokospalme : I have EXACTLY same device ... No fw find for this box.
          Mail sent to Ms. CHOW , [email protected] (the manufacturer of ZXSD board) :
          "Hi, Ms.CHOW !
          Please, can You help me ?!
          I bought R-BOX media player, based on ZXSD-Z X005 V02 board (see pictures in attach) ...
          Don't know why , but my device is bricked ...
          I need the original firmware and the advices on how to reflash my Android box ...otherwise my little son will be verry dissapointed ...
          Thank You in advance for any answer !
          Sorry for poor english ... Regards !"
          Answer :
          你好:
          你的BOX现在是什么问题,不开机吗?我们可以发新的软件给你。如果还是解决不了我帮你转我们 工程部。"
          Still waiting for an working firmware and reflashing procedure ... Maybe if you send a similar mail, with same content, will be receiving an answer ...
            Fratello, If you have exactly the same model as mine, it shouldnt be the problem to get the stock riamware running on your box!
            You can get the correct stock firmware from user BART_TECH, and flash it with the "RK Batch tool":
              Thanks, kokospalme ! It's this fw rooted ?
                Just received "fresh" (?!) fw for my R-BOX, from szzxsd.com. Link : http://pan.baidu.com/s/1qWPloAg
                Not tested yet ...
                  Hi fratello
                  Not tested yet ...
                  Hi, did you already tested the fw?
                  how did you flash it, using the Sd card?
                  regards
                    regards
                    I have exactly the same question , my R-box doesn't go into recovery mode. I have tried everything the button at the bottom (recovery), pressing both power & recovery buttons, short-cutting 7,8 ; 8,9 ; of the NAND chip, while connecting it via OTG to my PC. The later doesn't even see it. I also tried to flash the images you provided in this thread before: first I used tool Win32DiskImager to write image to SD card, then put the card in slot , then power up and press recovery button.
                    The only thing I've got is the green android robot stuck in the corner of my screen, no R-Box logo.
                    So here is the sequence: when connect power adapter - the red light is on, when press power button - blue light is on, then green robot in the corner pops up.
                    When connect via USB to PC only, the blue light is on, without going through red light stage , which is weird. When press power button and recovery button at the same time - no lights at all, everything is dark, no green robot, the end! Only fully taking power adapter out can help to restore to initial state.
                    Please help with advise, I've ran out of options.
                    Thanks in advance.
                    P.S. I have ZXSD-Z X005 V02 board.
                      I was able to put my box in flash mode using this method : http://vondroid.com/resources/t-r42-.../#.VECqc2eSyE4
                      And lewy say :
                      Originally Posted by lewy20041
                      it gave me a little headache to, but now i think its quite easy to get the box recognized.
                      1. unplug all cables from device.
                      2. plug micro usb otg cable into device and into pc (nothing else)
                      3. press and hold litle restore button on which is under device
                      4. plug in power cord (remember to stil hold restore button) and you are in flash mod
                      5. on first time it may not work before driver are instaled but later its working every time.
                        And lewy say :
                        Thanks man, really good advise. But somehow this doesn't work for me, the problem is that I don't hear a sound from windows telling me that a new device has been found, if I follow your instructions precisely. The device seems like alive , but I have some doubts about it. Any other ideas ?
                          Change:
                          -cable
                          -USB port (use one of backside of PC)
                          -PC.
                            Change:
                            -cable
                            -PC.
                            Sorry, didn't help.
                              "PLEASE NOTE – If it didn’t work or Windows automatically installed a driver you will need to completely remove the driver from the system and start over. To do this varies between systems but basically you will need to locate the device manager on your PC and find a USB device called “RK31SDK″ and completely remove and delete the driver from the system."
                              From here : http://blog.geekbuying.com/index.php.../#.U1990aLC6ZQ
