CR11S/CS968 CloudNetgo Ap6210 Cam5640 1080p 201301106 PRE-ROOTED Stock ROM
I also just got a T01 from geekbuy last night. I have to say so far everything is working. The rom is 20131126.115048 and it already pre-rooted which is freaking great. There is one thing i notice is the power bottom on the remote don't seen to turn on the unit. But funny thing is when I turn on my TV it it automatic turn on the unit too so i guess I can live with that.
Tested:
- Cam: Tested via Skype - Work quality not so great but its a 2M cam so can't ask to much. But video show up some what too red. Maybe lighting i don't know.
- 1080P: Tested via mx player - 1080P work out the box. Played 3gb+ MP4 and mkv file with no issue via LAN from NAS.
- Wireless: Work but to bad not 5G. The best I got was 70mb/s which should be the max because the unit is right next to the router.
- Mic: Work
Test Spec:
TV: Sharp 46 LCD 1080P HDTV
Remotes: Factory and Mele F10 Pro
Router: Asus RT-N66U
NAS: Synology DJ212
P.S Btw the factory remote is unless you have to pretty much pointing at the unit directly to be able to use it.
Originally posted by Tech1 View PostEven though this is a 1080p ROM build, the "Libmedia.so Hack" by Stafstorm of the Neo X7 Forum has been installed/Built IN, this ROM, just thought I would let you guys and girls know, enjoy ...
Originally posted by resansid View PostHi Tech1, Is libmedia hack as notifed here succesfully tested with xbmc. This is the rom I am using and cant get the xbmc to produce 5.1 on optical.
Originally posted by Tech1 View PostYou should be able to produce 5.1 AC3 digital audio ...! I'm right now in the process of uploading a CR11S/CS968 NEW ROM Build 1080p 2MP stock ROM dated 20131205 built IN libmedia.so hack ....
Hi tech1. Have you posted this new ROM yet?
Currently I have the cloudnetgo ROM flashed on my box, but i can't get wifi direct to work. I can establish the wifi direct connection, and I can send files from the box, but not receive files. Also can't get screen mirroring/Miracast to work as this also uses wifi direct.
I would appreciate if you could test these features on your ROM.Last edited by daviddem; 29 December 2013, 06:25.
Originally posted by daviddem View Postedit: sorry just only saw the thread you made with this new ROM
Originally posted by Tech1 View PostGuy, I'm going to be up front with you, I know nothing about what you are talking about at this time ... Yes, this 5MP 1080p ROM build is the latest ROM build dated 2013/5/12 ...
This feature seems to be generally buggy in Android, I need to update my phone and tablet to later android versions to see if this has improved.
Originally posted by jaygreene24 View PostAnyone test this rom with NHL game center LIVE?
Originally posted by jaygreene24 View PostI have the 2MP camera one. Does that matter?
Sent from my GT-I9300 using Tapatalk
http://www.freaktab.com/showthread.p...Ready-20131205 ....
Originally posted by Tech1 View PostYes it does, then you want this one found HERE
http://www.freaktab.com/showthread.p...Ready-20131205 ....I flashed it yesterday and it definitely improved. Video streaming still sucks though even with XBMC. The NHL app works but very quickly goes grainy then stops completely. Seems the box can't keep up with speed or quality of the stream. Anyone else having streaming problems?
Also still randomly reboots. I did have an external "powered" 3.5" HD attached and have since attached it to my router instead. I think the so called 3A power supply is pushing a lot less... Any idea where to get a replacement? I'm in Victoria, BC and I think the only source here is "thesource" (old radioshack) but matching the barrel connector might be a little tricky. Too bad they didn't go with some kind of USB connection since its also 5V and you can get various amp PS's. Is it possible the power supply is causing the slow streaming?
Last thing, anyone know how to map a NAS drive in Android? I can access it through Esfile explorer but I like to use Bittorrent and it won't allow me to use it as a download location.
Originally posted by jaygreene24 View PostAwesome... Thanks!I flashed it yesterday and it definitely improved. Video streaming still sucks though even with XBMC. The NHL app works but very quickly goes grainy then stops completely. Seems the box can't keep up with speed or quality of the stream. Anyone else having streaming problems?
Originally posted by Tech1 View PostGet this one, you will not have any problems, if set up correctly, go HERE
http://www.freaktab.com/showthread.p...BMC-quot-READY
It no longer reboot frequently or at least it hasn't in the last 24 hours. Although NHL LIVE is still doing the same low quality stream and freezing. XBMC has better streaming but doesn't playback anywhere near MX Player unfortunately but the streams look a lot better and seem to connect quicker.
Maybe completely unrelated but I was having trouble with Chrome browser on the last few roms with it rebooting the system. Now it doesn't reboot but noticed a Wimp.com video always plays at half speed like a broken record. This is the link: http://www.wimp.com/trainsdog/ It plays completely normal on all my other devices but not CS968. Weird cause other wimp video play fine on CS968. Is there a different format being used here?
Also, when I use Bittorent it starts downloading but after a few minutes it says the location is "read only". Maybe something with Bittorent, is anyone else successfully using pirat**** browser with Bittorent?
Thank you for all the hard work on this! I look forward to any new releases!!!
There are currently 2284 users online. 2 members and 2282 guests.
