ive already rooted and flashed so should i return it? its going to be a long haul all the way back to china
defective screen :(
defective screen :(
i have just recieved a pipo m9 max and just found out when i press hard on near the center of the screen you can see some sort of bright white lights lines like it wasnt glued properly
ive already rooted and flashed so should i return it? its going to be a long haul all the way back to chinaLast edited by elim; 17 December 2013, 15:20.Tags: None
You can reflash stock ROM and proceed with the warranty.if you appreciate my efforts this is the link for any donation:
Originally posted by FireRider View PostHi elim,
if your screen looks similar to the attached Pic you can fix it yourself.
Just let me know, I will post the workaround
I have something similar to that on my M7 Pro but without the yellowing around the ring. Could you post the fix for me? Thanx! Daz.
AW: defective screen
hey everyone,
i just had - as far as i can tell - this problem with my tab (black circle in middle of display) and short of returning it my vendor gave me the clue that saved me the trouble..
so here's what i got: the problem seems to occur when the tab is exposed to a sudden change in temperature - at least that was true for me
simple solution: get the tab working real hard, the tip i got was to let a video play in endless loop until the mark is gone (i used mxplayer), they said it could take some time, after some hours i helped the process along by placing the display in close proximity & facing the radiator.. and it really worked
.. so the magic ingredient was: heat
hope that helps, evenif the thread is somewhat old..
regards
TheEnvoy
Gesendet von meinem M7pro mit Tapatalk
Yeah, I have that same problem with my Pipo M5.
When I got it, it had a black bubble looking mark on the screen. It went away after several minutes of being on.
Now, I notice the spot returns if I don't turn the tablet on for a while...but it always goes away after several minutes of use. I think it is a weak seal in the glue or something.Randy
There are currently 1154 users online. 2 members and 1152 guests.
