T-R42 2.0 Board Firmware by lewy20041
Power Supply
HI Which power supply would people recommend.
The problem I was having was the unit would not power on (switch) and remain on. By chance I powered the flashing port and hit the power on button and the unit cameup and stated running. (afer flashing wassers Rom and then last gasp went back to geekbuying firmware).
2nd question is this firmware different from Geekbuying. I seen Lewys sig n install notes.
Originally posted by robot20 View PostHI Which power supply would people recommend.
I had a box when i turned it on kept going off so i just turned it on and kept taping the box and it worked
Originally posted by iANGELgr View PostI try the original XBMC 13 Gotham AND BeyondXBMC but I have the same problem, I cant play any video
Must I return the device back to GeekBuying???
you must be doing some thing wrong because i have put it on 60 boxes and even with out the 1080 kernals can get every thing to play perfectly ...
how are you flashing the firmware
Originally posted by jayman1309 View Postyou must be doing some thing wrong because i have put it on 60 boxes and even with out the 1080 kernals can get every thing to play perfectly ...
after I use RKBatchTool 1.7 and try T-R42 2.0 Board Firmware by lewy20041
but without any luck
Originally posted by iANGELgr View Postfirst i try with original firm that the device came to me.
well then there is something wrong with you box its prob a rk3188t not rk3188
try flash again and see wat happens cause it works for me and the 60 boxes i have done
There are currently 1902 users online. 2 members and 1900 guests.
