i know this prob sounds stupid i have downloaded every thing im just wondering how do you flash the kernal and put it in to 1080 mode
T-R42 2.0 Board Firmware by lewy20041
kernal flashing ...
Originally posted by moebeman View PostNice. I have a question did you try to play 1080p dts mkv files?
Whats the results smooth smooth playback ?
Its okay j got it working every thing good .. use the latest beyond xnmc for 1080 playback... thankz to lewy20041 for the hard workLast edited by jayman1309; 27 April 2014, 02:54.
Originally posted by oxicsp View PostHi, i've downloaded this firmware, but i don't know how to set 1080p mode Kernel, neither where i can find it. Couls someone help me?
Thanks in advance...
...... its preset at 720
...... you will know when you changed it the boot screen is smaller like the x in the middle that means your in 1080p mode then just plug it back in to your pc or laptop and flash the kernal .... let us no if this helps
Originally posted by oxicsp View PostThanks jayman, finally i discovered it. Now i have problem with Audio Passthrough!!!! I only get noise on my receiver when i use AC3 or DTS channels. With wasser firm it works well
Originally posted by jayman1309 View PostNo i just use beyond xbmc 3.4 beta works super 1080 playback smooth
Originally posted by chico0106 View PostHow do I get beyond xbmc I'm a newbie I don't even know how to flash this firmware on the unit is there like a flash tool I use? If so do you know the download links I need to install this custom firmware? I see there are a couple of different firmware a like this one and wesser or something like that. Thanks for your respond your help would be greatly appreciated
Originally posted by jayman1309 View Postno im home now for a bit i dont know wesser one i know that i have put this one on 60 boxes and the best and most stable iv used
this the beyond xbmc that i use http://1drv.ms/1mGBn5k
There are currently 1389 users online. 2 members and 1387 guests.
