T-R42 2.0 Board Firmware by lewy20041
    Originally posted by rceccleston View Post
    The included remote functions well to navigate the ROM and various applications like Netflix and YouTube.
    However, I would suggest the default key operations could be tuned to better suit XBMC, but this is beyond this topic.
    Sent from my M6 using Tapatalk 4
    Why are you even posting this? This was not directed at you, the rom was modded by lewy20041 and is able to run his version of the software that has an issue with it that has been discussed in another thread concerning this rom.
      Because this thread is titled firmware rather than XBMC...
      However, any issues are best discussed to find a resolution.
      Regarding the other thread, what issue are you experiencing on this ROM?
      I am continually running the latest nightly of Gotham without any issues as a MythTV frontend.
        Originally posted by lewy20041 View Post
        use wendal tools to unpack the firmware if you need kernel.
        or get it after instalation both 1080p and 720p are in system/preinstall folder
        Hi levi20041,
        did you build this kernel, or is it only a patched kernel?
        I would like to get the kernelsource with config, to be able to build a new kernel with full v4l-support for my dvb-c-adapter.
        I have crosscompiled a driver for my Wintv-hvr-930c-hd.
        But some symbolic links not working, because not implented in v4l-core.
        Please, can you tell me where to get the kernel with config for rev.2-board?
        regards
        Daniel
          lewy20041 any update on your justxbmc to getting the remotes working properly?
          Its Christmas mate.
          Give me some time:"
          Everything is possible if we work together!
          ApkFreak
            Its Christmas mate.
            Give me some time:"
            Merry Xmas Lewy. Thanks for all this hard work on your ROMs making our Christmas Android TV watching awesome!!!
              Originally posted by stahlwolle View Post
              After turning off and on my wifi is poor again
              I can turn the Antenna in every direction, its not even able to build up the Appstore startpage so it really seems to be a software bug
              Do you have anything connected via bluetooth? I had the same issue when I connected a bluetooth speaker to the T-R42 and used wifi. While still connected to bluetooth device, I toggled wifi completely off and then back on. It fixed the issue. However, I had to do the procedure every time I reconnected a bluetooth device to the T-R42 or turned it off.
              The alternative is run a cable to the T-R42. Hope that helps
                hello, how can I find oveclocked 1080p kernel for t-r42 v2.0 board ? please advise me. best regards.
                  I will upload some for you
                  ApkFreak
                    many thanks lewy, where will you upload them ?
                      Not today as its late here. Maby tomorow.
                      I will upload it to mediafire and post link here
                      ApkFreak
                        Not work with Jesurun.
                        Hello Lewy20041.
                        I install your firmware with my Jesurun DX05 with bluetooth and not works. I use firmware by wasser version 1.2.3 and works ok. I send you link to my stock firmware but hotfile is not working now - if you want i will upload in mediafire or else services.
                        Thanks for your work.
                          Here is the OC kernels pack:
                          Download
                          Make sure that you flashing 720p kernel in 720p mode and 1080p kernel in 1080p mode.
                          !!Im not responsible if someone will flash this kernels and damage his device!!
                          !!Its only for people that know what are they doing!!
                          ApkFreak
                            Re: T-R42 2.0 Board Firmware by lewy20041
                            Originally posted by dobosz23 View Post
                            Hello Lewy20041.
                            Sounds like your Jesurum DX05 is a T-R42 V1 supported by Wasser rather than T-R42 V2 supported by Lewy20041.
                            There are many hardware difference between V1 and V2 so it maybe wise to run Wasser's ROM's for full hardware functionality.
                            Sent from my Nexus 4 using Tapatalk
                              Download
                              Thank you very much you are good man. Happy New year.
                                WIFI issue
                                Hi to all. I have receive 5 pcs. t-r42 v2.0 hw rev. and each ones have very bad wifi perfomance - 0.2 mb down., 3-7mb ( signal strench is good). I have tryed all existant firmwares(stock and lewy) - same result(((
