lol.. hop too my friend!! you are more than welcome..
** ROM ** Polaroid AS7 ** ROOTED + TWRP**
Willing to Test Elektrik A/S7 Rom
Count me in on testing.
Originally posted by Oskker View PostI would test it. Let me know when. Thanks
Sent from my A/S7 using Tapatalk 4
Originally posted by guessyet View Postlol.. hop too my friend!! you are more than welcome..
Originally posted by Oskker View PostHow's the process going on the rom?
Sent from my SAMSUNG-SGH-I747 using Tapatalk
Originally posted by jtintle View PostThat sounds great for us 701C users
sdcard / extsd switch?
Guessyet, is it possible to incorporate the switch a different way than a modified vold.fstab in /etc? for example in the file, all you had to do was change the mount points around from "sdcard to extsd" wherever it appeared in the fstab file. i downloaded and flashed your rom, and i couldnt get the hack to work with this rom. i did remember to get root explorer and change the permissions of the original vold.fstab so i could edit it, but to no avail. any suggestions? i loved having 29gb of storage vs 828mb lol Btw, i like having a recovery so i didnt have to reflash in case things went wrong. good work bro.
Edit....i managed to put a space in there somehow, making it not work...but I managed to get it to work.Last edited by MidnightMoon; 14 January 2014, 08:40.
Props to guessyet - thanks I needed this
Bought the TAB cheap and its was buggy and laggy at best for me.
Info for those who are looking:
Polaroid AS/7 (On back it states "Model S7")
BN: AS-20130827
FCC ID:RBD-V7A20
Installed Phoenix Suit (App is a sticky on this forum)
Flash tutorial HERE worked for me (I only had to press Home and plug in - I didnt have to press power)
Thanks again. Need any testing Ill help out.
Originally posted by MidnightMoon View PostGuessyet, is it possible to incorporate the switch a different way than a modified vold.fstab in /etc? for example in the file, all you had to do was change the mount points around from "sdcard to extsd" wherever it appeared in the fstab file. i downloaded and flashed your rom, and i couldnt get the hack to work with this rom. i did remember to get root explorer and change the permissions of the original vold.fstab so i could edit it, but to no avail. any suggestions? i loved having 29gb of storage vs 828mb lol Btw, i like having a recovery so i didnt have to reflash in case things went wrong. good work bro.
i just uploaded a rom for the as8 which has the sd-swipe included.. it will take me a couple of days to get the changes moved to the s7 and s10...
Is there a link to the driver for win 7 64 bit? Still having a tad of difficulty getting windows to install anything for the s7. Even with pheonixsuit drivers installed. Still wants to come up saying driver install failed for MTP
USB Device. I can flash no problem using the home + plug in method.
Originally posted by MidnightMoon View PostIs there a link to the driver for win 7 64 bit? Still having a tad of difficulty getting windows to install anything for the s7. Even with pheonixsuit drivers installed. Still wants to come up saying driver install failed for MTP
There are currently 4186 users online. 0 members and 4186 guests.
