Are you using the ROM I uploaded or one downloaded from Southern Telco? Are you using an app like Android Tuner?
@Purdy_Birdy,
There shouldn't be a situation where you have half stock and half root. The only way for files to be persistent across flash procedure is by *NOT* selecting format in Phoenix Suite when flashing. The errors started after you reset and flashed the latest Southern Telco image?
