Retired - HardwareGuru Rom 03 - Firmware for Neo X7
    Originally posted by zapto View Post
    Really nice rom! smooth 1080p, mele f10 support and audio pass-through ok.
    Does anyone knows why the box goes to standby/switch off video occasionally? this happens in all roms I've tested (006c,007,008). If XBMC is on focus when this happens, I need not only to pulse the power button but also the home button to get the screen again. Any clue?
    You meen it is like a button is pressed but it was not?
    Some have issues with the IR remote reciever(onboard IR eye) when there are IR signals in the air the box can do strange things.. try covering the front of your box if that is the case do the IR eye/led is covered and see what happens.
    Otherwise i dont understand the way you explain it can you give some details?
      I am not on this ROM so it is only a general suggestion. Look for developer options in settings ( may not be enabled by default, I think it is build number that you click repeatedly to enable). Anyways once in developer options check the box for never sleep while charging. Actually it probably says always awake while charging.
        its work in T428?
        Thanks....
          Ok ya freaky deeky dike builder wheres the x5 and x5 mini for me to test and any chance of making Rom for the cr11s seem to run Wight fewer issues then the x7 ... cloudgonet.
            Netflix playback?
            How is the netflix playback on this rom?
              Thank you for the rom ,Guru. Its working great. Do you think you can cook one up for the X7 mini?
                SPDIF AC3
                I've got many problems with AC3 over spdif DTS is no problem.
                Firmware: 1122 / 008
                Audio Settings: S/PDIF Passthrough
                Devices used with minix:
                TV Samsung LE46A786R2FXXH - connected via HDMI with minix
                DVD Samsung HT-Z320 - connected via Optical with minix
                Video testers:
                DTS in MKV - 5.1 is working fine
                AC3 in AVI - no sound
                What should I do to have DD 5.1 AC3 via S/PDIF?
                Maybe something with advanced settings???
                Code:
                <advancedsettings> <audio> <resample>48000</resample> <forceDirectSound>0</forceDirectSound> <audiophile>0</audiophile> <audiosinkbufferdurationmsec>50</audiosinkbufferdurationmsec> <allowtranscode44100>0</allowtranscode44100> <streamsilence>0</streamsilence> </audio> </advancedsettings>
                  Video testers:
                  Code:
                  This is not related to my firmware. ( this is not based on 008 )
                  Please start a topic on its own for it or read here:
                  For sound issues in xbmc on minix:
                    http://minixforums.com/threads/how-t...nd-spdif.2071/
                    Should it work with your firmware?
                      Dont hang me for it but.. related to my roms and your question:
                      My test team: No isues reported
                      Public forums: No isues reported
                      I think it should just be working fine
                        Originally posted by gamajunior View Post
                        its work in T428?
                        Thanks....
                        I dont know, i dont own one to see it it works.. but if x7 roms runs on it this should too.
                        Hey mate, good to see you arround
                        Probably i will do the X5 and x7mini soon.. if i can find some spare time..
                        Send me a cloudnetgo box hahhaha
                        Yes it works fine. ( see some posts back )
                        Yes i am planning to so so if i can find the time to do so.
                          Okay I'm gonna flash the rom tonight and hopefully everything works fine,all the roms I've tried I had problems with AC3 sound DTS working fine but AC3 no sound trough all the speakers only the front speakers.
                            Let us know, i have same problems only 2 channels of audio comming trough...
                              Good to see you to waiting on shipment ill let you know when they arrive.
                                its work in T428?
                                Thanks....
                                i already answered that question...! yes, it does.
