THIS IS A TEST ROM! It is not an official release from Arnova! I have taken the stock ROM and fully rooted it and added google play. You are on your OWN with this! I cannot NOT gaurentee this is NOT a brick ROM! BUT it boots on my Arnova 10G2 so I am pretty sure it is not a BRICK
I cannot test the Google Play stuff nor the Sync Adapters. So you guys will be my test dummies. I will edit this post based on user feedback!
Again SPECIAL THANKS to the user on the Italian forum for dumping this ICS 9G2 ROM! And big thanks to FreakTab user fillab for sending me the ROM today! You guys ultimately MADE this ROM happen
Your the best and THANK YOU! Great community of people!
__________________
Features of this first Finless 1.2 ROM - ICS for the 9G2
1) It's fully rooted! System is now mounted is RW. System was already ext3 but not RW.
2) System has been properly blocked for NAND memory so it should perform a little better than before.
3) Google Play Store has been added. Along with the following Google needed things:
- Calender Sync Adapter
- Contacts Sync Adapter
- Updater
- Google Search Bar
- Framework files
These should allow you to now sync contacts and calendar.
- Youtube
If you guys want I can update this later with more Google Apps.
4) SU and Superuser.apk for ICS is installed! These are different version needed than GingerBread
5) Full root access is given by permissions set when making the ROM
Note: Pre-installed is Gplay 3.5.15 but if I did this right, it should upgrade to 3.5.19. Please let me know if this works!
So you all know. boot.img was very different! It took me a while to figure it out. It is not like the Arnova GingerBread ROMs. However, I got it apart and cleaned up the crap left behind that is not needed!
Anyway for those that want to try it, here is the 9G2 ICS ROM "fully rooted" with Google Play - Version 1.2 by Finless:
DOWNLOAD ROM -> 9G2 ICS FULL ROOT with Gplay ROM V1.2 - by Finless (130 megs)
PLEASE READ THE README.TXT inside this kit.
YOU MUST and I am serious about this MUST EraseIDB and click the loader check box in the flash tool! This has a new loader version 2.14 and you must use it! Actually I tested and Loader 2.08 (old version) works too but it is slow compared to the new version. BUT do what I say please to be sure!
Enjoy you 9G2 users and let me know how it all works!
Enjoy!
.gif)
P.S. Same comment as before about fair use and acknowledgment by those that have less scruples than others. Play fair!
