Arnova 9G2 ICS - Full Root with Google Play - ROM V1.2 by Finless
No it's not possible that I know of and I have tried. The new play store requires .xml files and .jar files that must be located in folders in /system. So to get it on there working it seems you must be rooted.
Hi Bob (and others of course), i have a few questions;
1) do you know of any reason why there's only 227mb of system storage available? I seem to be using most of it and I'm wondering if this is normal. If it's not, how do I go about growing this?
2) is it possible to remove system apps which are of no use to the 9 g2 (I'm thinking here about dialer, sms and bluetooth stuff)? I've removed some with titanium backup but as you're the system de-bloating king you may have other ideas
3) I've noticed in build.prop ' dalvik.vm.heapsize=256m' should this not be set to 512 to match available memory (I have a feeling it's correct but just wondered)
All in all everything is working well I just want to squeeze as much out as possible.
Cheers, Paul
Sent from my AN9G2I using Tapatalk 2
Nrtflix wont work....
Originally posted by Finless View PostNo it's not possible that I know of and I have tried. The new play store requires .xml files and .jar files that must be located in folders in /system. So to get it on there working it seems you must be rooted.
Hello Bob, just 1 question for you, can you please explain why netfix wont play on my tablet, i have
Arnova 9 g2 flash with your 1.2 ICS rom...By the way, ths is a wondrful Rom
Problems with WiFi
Hi Bob,
first of all, great work of you. Everything works fine except my WiFi. There is a little Problem after reactivating the screen after about 30 minutes. It needs a long time to reconect to WiFi. The symbol turns blue, but it is not possible to use Facebook or Browser. Just after i switch the WiFi off and on it works again. Do you have any suggestions?
CU Libretto
hey folks,
first of all, thank you bob for this nice rom!
got the tablet since 2 weeks andinstalled ics on the first day,runs as a charm.
however, battery percentages seem to jump quite a bit, when approaching 30% or so, battery suddenly drains quite fst', I calibrated several times, but no improvements. also when loading bat, after 0% shutoff, it immediately goes up to 30% again...
dunno if its a ics bug or defect device - today i got about 3-4 hrs battery time with wifi off dispay 50% and playing scummvm...
any ideas? still have one week to return it to amazon...
ch
eers, dennis
ch
eers, dennis
Ask people on here they will verify it. As for battery life itself it all depends on what you are doing on your tablet. Gaming will most definitely drain down your battery quicker, WiFi not so much and leaving a tablet in standby.
So lower your expectation on battery life if you are a gamer
Sent from Xperia Mini Pro ~ Android 4.0.4 ICSPlease consider donating to purchase tablets for Finless Bob to continue his work. This will help in the creation of custom roms and build an even stronger development base for our community. Thank you for you support!
</form>
Originally posted by Finless View PostGuys.... this is a STOCK ROM and all I did was root it and add Google Play.
first of all: Thanks for the great work!
I've installed your 1.2 and it worked smoothless, however, the 9G2 potentially doesn't have enough horse power for ICS so it's a bit laggy ...
Archos has a newer image on their web-site (4.0.7) so I'd like to try what kind of changes they might have done to the original, however, to be able to use that original image I need to have the Firmware-Updater which is missing in this image. It's also missing in the "STOCK ROM" your image is based on, so the procedure How to install a firmware doesn't work :-(
Any idea about how to get the original .aos image installed on the 9G2?
Might also be a good base for your next round ...
Thanks - any information I can get is appreciated!
Originally posted by Finless View PostI just went to www.arnovatech.com and I do not see a 9 G2 or a 9G3 release?
I wasn't aware that there's a difference ...
does have a newer version ...
There are currently 2682 users online. 2 members and 2680 guests.
