(if not satisfied, they can always reinstall the original pointer, perfectly centered)
Coloured pointers, flashable in recovery, for Minix neo x7
Originally posted by saddas View PostHi, gio965!
Could you explain me how can I change firmware before flashing for get new pointer (for example smart)?
If instead you want to change firmware, you must specify the firmware that you want to install (and your actual firmware...wasser v1.0.2?)Last edited by gio965; 06-03-2014, 20:36.
Originally posted by gio965 View PostHi saddas, if you want to try my pointers you must only choose the specific one (jb, wasser v1.0.2 or quickshot v3.1).
Thanks!Last edited by saddas; 06-04-2014, 10:11.
Originally posted by saddas View PostYes, my firmware is wasser v1.0.2. How can I change pointer to smart pointer in the firmware before the flashing?
Thanks!
I'm not so expert to include a new pointer inside a rom, but I can give you only zip packages to patch.
Originally posted by saddas View PostHI, gio965!
Thanks for your work again!
Couid you also make Stok_pointer_smart for wasser 1.0.3 rirmware?Last edited by gio965; 06-12-2014, 13:10.
There are currently 2010 users online. 4 members and 2006 guests.
