Originally posted by Finless
View Post
I am going to be away most fo the day today. My Dad is getting out of the hospital and Iam going to hang with him for awhile.
Anyway, not sure I understand the question?
Your tablet is 4gb
I allocted extra space is /system for rooted apps. This does not get reported on the memory info screen.
So /system with ext4 is 315 megs
I also allocated 2 gig of "user" space in my 2.0 ROM (it was 1 gig on my 1.5 ROM). This is what is reported as "internal storage". This is where APPs go when installed, user data that APPs create, databases, etc.
This leaves about 1 gigs left for what Arnova uses as "the internal sdcard" or NAND FLASH.
Now what the screen says for NAND flash is screwy and always has been. it is reporting the same number always that I see. Total space 1.03gb and available space as 1.03gb for instance. Again this is your internal sdcard.
Now here is one little problem I have explained before. When you insert an external sdcard Arnova mounts that as /sdcard thus making the internal sdcard memory no longer accessable. If you remove your external sdcard and reboot you will see the memory settings will show you about 1.x gig of sdcard space. This goes bye bye when you insert an external sdcard.
Now finally whats happens to memory. APPs decide if they are going to store data in /data (internal storage not SD) or use the sdcard. Almost any APP that creates a SQL data base will use /data for that. Data that is considered secure like user accounts etc also go in /data.
Uninstalling apps may or may not clean up this area!!!! So if you installed something that sucked up a lot of user space and it did not release it, only way to fix it is possibly with SDMaid and have ot look for tombstones or APP data that is no longer used. OR the hatefull "data factory reset"
bOB
Your tablet is 4gb
bOB
Glad to hear your dad is comin' home Enjoy your time with him and we will be here when you return.
