cx-919ii, Bluetimes BT919, GM282, DM 918 etc. updatable to Kit Kat 4.4.x without bricking the device!!!
Originally posted by Max One View PostDownload this official firmware from Bluetimes BT919 (it also works on other J22 or cx 919ii devices) and read the RK upgrade instruction.pdf. Good luck.
http://www.sendspace.com/pro/dl/7bzbci
Am I stuck with KK?
Thanks!
Originally posted by pmgahan View PostI already tried that but whenever I try to restore it fails and then gets stuck in waiting for loader start.
Am I stuck with KK?
Thanks!
After 1st flash i had an error
It failed yeah but the good thing was, the stick was in maskmode = blue light. I flashed the same firmware again and voila the stick is running back on JB.
Small guide
1. open RKBatchTool.exe
2. change language to english
3. press ... to set the firmware (which u want to flash) into the "FW Path:"
4. hit restore and wait
If u get the same error as me above flash again and ur done. GL
Or
1. Open Androidtool 2.1
2. Go to "Upgrade Firmware"
3. Click on "Firmware"
4. Pick the firmware which u want to flash
5. Click "EraseFlash" after erasing the flash u are in maskomode
6. Click "Upgrade"
7. wait until its done.
GLLast edited by Max One; 06 April 2014, 00:17.cx-919ii
Danke shoen, Max One!
You solved the J22/CX919ii issues. This is the first bootloader/kernel/ROM combination that works flawlessly with my J22. No flickering, everything works. I know D33 and Finless did the development work, but you put it together.MK808 w/Omegamoon kernel, CWM recovery, & Finless 1.7 ROM
Here is the full list of bootloaders if the above does not work for anybody: click me
Other D33 kernels if anybody wants to try: click me
This combination has worked for me too, but I have to admit that I have heat issues and am afraid that I might fry the chip since I do not have the modded heat sink/radiator.
Noderat's "all stock" kernel also made by stick hot when using Beyond XBMC. I will give it another try with 2.07 kernel and "minimal specifications" or similar setting in XBMC.
Thanks for putting this in one thread Max One.Tronsmart Orion R68 Meta
CS968 -> HTC_T018 v4 20131216 with MTK
GM282 (aka CX 919 II aka J22) - dead
Although flashing went well, booting clearly does not. I got the same mobo as the OP (CYXTECH_RK3188_909 V1_1); both the combinations of kernel_AP6210-J22_SD_v207 & boot720 as well as kernel_AP6210-J22_HD_v207 & boot1080_large result in a bootloop after 2-3 seconds of the GoogleTV logo. Any ideas? For the time being going back to BT919_1123 :<
There are currently 3206 users online. 0 members and 3206 guests.
