cx-919ii, Bluetimes BT919, GM282, DM 918 etc. updatable to Kit Kat 4.4.x without bricking the device!!!
Originally posted by Max One View PostBefore flashing a rom u have to always Lowerformat or could put ur stick into maskmode and then try to flash again maybe it works then. gl) and pressed LowerFormat before pressing Run.
Hi everyone! This ROM practically solved the resolution issue for me. However, the system crashes after some time.
For example, I'm watching a movie and everything stops, lines on the screen pop up (mostly two color ones), everything goes black and then I need to restart the box.
I thought I installed the wrong kernel but I didn't - I have a non-t CPU and I installed the non-t 1080p kernel.
Can I do anything? Does switching to 720p help? I can't try right now. Thanks! And this is a great ROM, huge thanks to everyone who participated on it.
Edit: The ROM doesn't work for me, the kernels don't.
1080p non-t - perfectly smooth, crashes with those lines and reboots after some time
720p non-t - crashes at the loading screen
Both t kernels flicker while watching video at an unwatchable rate, plus system lags in general
I hope there is a fix for this.
TWRP
Originally posted by Max One View PostHello Freaktabbers,
this thread is made for all the guys who ended in a brick after updating to Kit Kat. And yes, updating to KK without bricking the device is possible!
My PCB: 2013-06-17 CYXTECH RK3188 909 v1_1
[ATTACH=CONFIG]6027[/ATTACH]
I really wanted to update my tv-stick to Kit Kat 4.4.x, but stupidly it ended always in a brick. So i had to short pin 7 and 8 (on others maybe on pin 8 and 9) on the nand chip, to make my stick work again.
At the end I believed that these nandchips on this tv-sticks are somehow bad and not able to flash new bootloaders, for example 2.03, 2.07, 2.08. <-- ATTENTION, DO NOT FLASH ONE OF THESE OR UR DEVICE WILL BE BRICKED!!!
But thats not true, these tv-sticks will work with new bootloaders. You just need the right one.
What u need is:
1. Flashtool 1.3x or higher. I use Androidtool 2.1.
2. RK3188Loader-L-_V2.13.bin ---> click me
3. KK Rom
.. and you will see KK will work.
__________________________________________________ ___________________________
For those guys who dont know what to do, i have uploaded an All In One rar.
Download it here (click me) read the README FIRST CX919II -T428.TXT and you are good to go.
This Rom is for CX-919II and Tronsmart 428.
To know which kernel is the right one for you, you have to know which kind of cpu version you own.
If its the rk3188-t cpu u have to pick kernel_t_........img
If its the rk3188 non t cpu u have to pick kernel_.........img
Its very important to use the right kernel. If you use the wrong one your device will start but it will reboot randomly after few seconds.
HD kernel = 1920 x 1080
SD Kernel = 1280 x 720
Its also importannt to use the right kernel with the right boot.img. For example, if you want to use a HD Kernel then you have to use the 1080 Boot.img, SD Kernel --> 720 boot.img
The t kernel is clocked at (DDR and GPU are locked in this kernel, only CPU is overclockable)
CPU 1.4 ghz
DDR 528 mhz
GPU 445 mhz
The non t kernel is clocked at
CPU 1.8 ghz
DDR 720 mhz
GPU 445 mhz (<-- I´m not sure if its right maybe its a bit higher)
All use 1.8V for LCDC support and to prevent screen flickering
If you think your device gets to hot, install cpu frills from Play Store and underclock it to prevent heat damage.
Thats all for now, and dont forget to rate this thread. Thanks.
All credits goes to Finless and D33.
If u wanna say "Thank you" go buy him a beer.
Enjoy and have fun.
Max One
I followed your instructions and everything was OK. Stick booted to Android. Then I installed Dropbox, unplugged from computer and plugged to TV. Second boot finished on TWRP and not Android start at all. I have tried also reboot to System manually but this did not help. Always it finished on TWRP and refusing to go to Android. After this I tried flash system again with same procedure but after flash when I expecting reboot (point 3 in paragraph Flashing) is stick freezing. When I unplugged it form PC and plug to TV it is again stop on TWRP.
Please let me know what happened. First time it was OK but second is not working.
Originally posted by Johny View PostI followed your instructions and everything was OK. Stick booted to Android. Then I installed Dropbox, unplugged from computer and plugged to TV. Second boot finished on TWRP and not Android start at all. I have tried also reboot to System manually but this did not help. Always it finished on TWRP and refusing to go to Android. After this I tried flash system again with same procedure but after flash when I expecting reboot (point 3 in paragraph Flashing) is stick freezing. When I unplugged it form PC and plug to TV it is again stop on TWRP.
Please let me know what happened. First time it was OK but second is not working.Last edited by Johny; 29 April 2014, 17:03.
Great Guide
first of all my system language is german, so maybe I use the wrong terminology sometimes.
I tried to flash my stick, but I can't install the drivers. I googled a lot and found out that the "unknown device" must be found on top of the device manager (not recognized devicetype), which is not happening with my device. Win 7 recognizes it as a unknown usb device and throws (in the info field of the device properties) the error code 43 - device stopped.
I tried to point the driver destination anyway, but windows says all the time that it's using the optimal drivers already and installs nothing...
After that, i disabled driver signature enforcement in win 7, but it didn't help.
I also tried a second PC. So i had the problem on my x64 Acer Win7 NB and on my x86 Win 7 Thinkpad.
I also searched this forum and others and found nothing, maybe i searched wrong keywords?
I know it's not a problem with your guide at all, but maybe you know a trick or maybe a page where i can find some help...
Thanks in advance.
updated my cx919ii with this ROM
I'm very much new to TV sticks and so upgrading as well.
Thanks for the detailed instructions and the ROM, I was able to upgrade the device without any problems.
However post the upgrade, the WiFi is not working, the device keeps on displaying "Turning Wi-Fi on..." and WiFi is never turned on.
Also, device cannot be detected on my Win7 laptop post the upgrade.
Can anyone please help me with this problem?
Regards,
SaurabhLast edited by newCX919ii; 17 May 2014, 12:14.
Originally posted by newCX919ii View Postthe device keeps on displaying "Turning Wi-Fi on..." and WiFi is never turned on.
If the device driver is properly installed, it will be detected if you make it go in flash mode. Or did you mean "does not get detected in USB mode"?Tronsmart Orion R68 Meta
CS968 -> HTC_T018 v4 20131216 with MTK
GM282 (aka CX 919 II aka J22) - dead
WiFi not turning on
Originally posted by ghanashyaml View PostThis will happen if there is a mismatch between your wifi/bt chip and kernel. Open up your stick to see what chip you have and then you need to install appropriate kernel. For AP6210 chips, there are two variants and you can see two kernels in D33's Kitkat thread.
By not detected I mean, it doesn't go in flash mode.
Originally posted by newCX919ii View PostThanks Ghanashyaml for the reply. Isn't there any other way to determine the chip? If not do you know of any video demonstrating how to open the device?
Make sure you use Windows 7 and USB port 2.0 for going into flash mode. If drivers are installed, it should work. If you bricked yours, then you might need to go into mask mode, to unbrick it. Search on this forums, you will find enough posts about it.Tronsmart Orion R68 Meta
Ethernet
My WiFi was not as good as I wish so I have bought reduction Ethernet to micro USB. When I plugged it on stick did not recognized it and MAC was still 00. LED on the reduction is blinking so I assume that internet connection is OK. Is there something what is necessary to setup or this Rom did not support Ethernet at all? In this case can you recommend me any KitKat rom which support Ethernet on cx-919II with RK3188-T?
Originally posted by jorgefcbastos View PostHello, another one having this version.
Did everything like the procedure but when I click Lower Format there's an error and I can't finish the job.
Is there any clue of what is causing this?
[ATTACH=CONFIG]6475[/ATTACH][ATTACH=CONFIG]6476[/ATTACH][ATTACH=CONFIG]6477[/ATTACH]
Did you do this?
Putting the CX-919II/T428 into flash mode using the Flash Tool:
1) Remove any SDcard you may have installed.
2) Connected the supplied USB cable from the device to your PC. It will power up and windows
may detect the device. DO not worry about that. We need it powered up.
3) In the ROM kit run the ROM Flash Tool.exe.
If at the bottom of the flash tool it says "Found One MSC Device" then proceed to step 4.
If at the bottom of the tool you do not see "Found One MSC Device".
We need to make changes in settings to turn on USB storage
Go into settings and click on developer options. Make sure USB debugging is OFF.
Go into storage settings. At the top right are 3 dots. Click it and select MASS Storage box.
4) Now at the bottom of the PC flash tool you should see "Found One MSC Device".
If it does NOT say that, then repeat steps 3
5) Once it says "Found One MSC Device" in the flash tool click the "Switch" button.
6) Wait up to at least 10 seconds. The unit should reboot and the screen will be black (no output).
Originally posted by Johny View PostMy WiFi was not as good as I wish so I have bought reduction Ethernet to micro USB. When I plugged it on stick did not recognized it and MAC was still 00. LED on the reduction is blinking so I assume that internet connection is OK. Is there something what is necessary to setup or this Rom did not support Ethernet at all? In this case can you recommend me any KitKat rom which support Ethernet on cx-919II with RK3188-T?
Some remote help would be nice.
There are currently 4000 users online. 0 members and 4000 guests.
