http://freaktab.com/forum/tv-player-...9iii-rtl8723bs
cx-919ii, Bluetimes BT919, GM282, DM 918 etc. updatable to Kit Kat 4.4.x without bricking the device!!!
I'm experiencing that when I plug the device into a PC it *never* shows up. I've tried 2 different cables and 2 PCs. I'm able to get it to boot into the bootloader, but Windows doesn't even recognize that a device is attached (hence, there is nothing to install the drivers to). Anyone have any ideas?
When it's in the normal OS, it doesn't show up either... whether I select MTP or Mass Storage...
Hi ManiacDC ,
why dont you download a RK3188 Driver Package somewhere here or Google and install it , after that try again.
Maybe u need USBDeview to uninstall all the old USB Entries and try again.Run as Admin .... for Uninstall.
What kind of Windows ??? ..... / 7 is the best for this.
good luck
gefattern
Thanks! Turns out I had a combination of issues:
1. My main PC was having an issues detecting android USB devices. Sometimes it does that and I have to restart.
2. Before I discovered #1, I had tried both microusb ports on my device (one is 5v charging, one is OTG). Neither worked.
3. When I tried the device in another PC AND on my main PC after restarting, I used the 5v port and forgot to try the OTG port, I think.
I have Win 10 at home. I tried it today on a Win7 PC at work using the OTG port and everything is working fine! I just flashed... we'll see how it turned out. Thanks!
Hi ManiacDC ,
RK3188 or others have no BIOS , do you mean the "recovery.img" or another "kernel.img" or Firmware ???
For 1080p on this Devices you need a "1080p" kernel like hwdsl2 on Post#61 uploaded , but you need the
same Device.
Maybe it is better to look for a newer Device , if possible , like the new RK3399 or S912 Devices.
good luck
gefattern
There are currently 1878 users online. 0 members and 1878 guests.
