[ROM Download] Official Android 4.4 KitKat Firmware For RK3188T TV BOX and TV Sticks
re-hosted here -> hereMeasy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
This ROM (KitKat_T010) is much better but only 1280x720 resolution, unrooted and kernel locked.
I can't get sound on my TV Box (T CPU, RK1000 codec)? Can anyone else? If you get sound can you report what 'kit' you have?
Here are some unlocked kernels to test with the above ROM. Let me know what works and what doesn't. I'm particularly interested to here from anyone who gets the audio working in the original to tell me if mine have audio too. Bob says audio works with stock on the CX-919
unlocked kernels (1080, 1.6 CPU, 600 GPU, 720 DDR for both T & Normal)
AP6210/AP330 versions in TV Box and TV Stick versionsMeasy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Originally posted by d33 View PostThis ROM (KitKat_T010) is much better but only 1280x720 resolution, unrooted and kernel locked.
AP6210/AP330 versions in TV Box and TV Stick versionscx-919ii
yes i have a not-t version
well mine doesn't boot with stock kernel
with your 3.10 kernel it boots but is very laggy
with your 4 kernel it show ugoos then black then "cannot show this video mode"
hmm
tested with your old kernel that boots
when res. 1900x is ok
if i switch to 1200x also the screen goes black and says "cannot show...", well now i rebooted and 1200x shows ok on tv but all that with old kernel (laggy)
can you make 1900x kernel?Last edited by lonely2k5; 05 April 2014, 11:02.
My TV box is TV01 V3 (CS968), RK3188 "T" CPU with AP6210.
Here are my test results
(1) Kitkat_T010_AP6210_public_20140403, stock rom
WiFi + BT working
Sound over HDMI is working
Ethernet is working, MAC address assigned
All 4 USB ports are working.
IR remote - some keys work, probable not designed for my remote.
Camera/MIC/SPDIF - not tested
This ROM works very well. I could boot straight to KK 4.4 without using the powering OTG port method.
(2) Kitkat_T010_AP6210_public_20140403, with your "Kernel_AP6210_V4021_BOX.img"
I can boot up to the KK 4.4 screen. However, when I clicked on any icon, the TV box rebooted. There were also no status bars on the top and bottom of the screen.
(3) Kitkat_T010_AP6210_public_20140403, with your V3.1 kernel "kernel_AP6210_HD_v310_cpu1800h_gpu798h_ddr720 "
I needed to apply power to the USB OTG port prior to application of normal power to the TV box. WiFi + BT are working. Ethernet no MAC address.
Only two of the USB ports are working (The stock rom has all 4 USB ports working).
Antutu mark >20000.
Attached some screen shots
Cheers,
hkp168Attached Files
[ROM Download] Official Android 4.4 KitKat Firmware For RK3188T TV BOX and TV...
Originally posted by lonely2k5 View Posthi
no boot on these kernels for me CX 919II always "No signal"
My kernels don't boot
The stock kernel/rom doesn't boot
Nothing boots
Sent from my iPhone using TapatalkMeasy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Don't waste time with the beta kernels (v3.x, v2.x)
Donate to Finless
WiFi + BT working
Antutu mark >20000.
Cheers,
hkp168
Donate to Finless
Device GK525 RK3188-T, my new mod official KK Robertnik_mod_KK_GK525_v002.zip
Fast test:
kernel_AP6210_v4021_BOX.img
The inner camera and microphone does not work.
HDMI audio works.
kernel_AP6210_v4021_STICK.img
HDMI audio works.
My CPU-T 19k incredible...
"dupe urywa"
Good job!
Thank you.Last edited by robertnik; 05 April 2014, 15:21.GK525 My mod rom.
Originally posted by geekbuying View PostHI guys:
Rockchip release the official android 4.4 firmware for their tv box and tv stickes, today, we just get this firmware, it is special for the tv box which use AP6210 wifi module. If your tv box/sticks don’t use this module, please don’t flash, you will lose your wifi and bluetooth, please note!
We have tried this on MK908II and MK809III with AP6210, both can work well, please help to test more models, and report back.
The official firmware has fixed some bugs in the beta android 4.4 firmware, please flash and check.
One problem i find in this firmware is there is NO Google apps ( play store, gmail, google play service) preinstalled, It’s really sucks, don’t know why rockchip remove those in this official update, but i know we can add this by ourselves. I still tried to figure out how to install that by myself, if you know how to fix that, please leave message here. ok, here we go:
Firmware Download Link
password is geekbuying.com
ROM is not rooted, and you should root by yourself. Here i recommend you a easy root method, download the root tool here:
http://www.mgyun.com/en/GetVRoot
Run and install this tool in your PC and go to your tv box setting, and open the “USB Debug” setting, and just click Get root button, this tool will help you to get root. easily.
ROM is still base on 720p. and we are working with the developer,and will release the 1080p version soon.
The total performance of Android 4.4 Kitkat has been improved a lot than the Jelly Bean Android 4.2. It has less boot time, and system is much steady and fast.
Enjoy!
Screenshot:
Some hot selling TV BOX/Sticks with AP6210 recommended:
1. Tronsmart MK908II
2. CX-919
3. MK809III
4. MK918
Source from: http://bit.ly/1giWLIB
Thank you for the news , I hope that it means that soon we will get FINLESS3.0 or such ;-)
or NEOMODE ...
for installing the googleapps you can search for "GAPPS" (the package to be downloaded by android version ) and install it through CWM .
the gapps package is for those that installs CM roms that are naked from all the google stuff
There are currently 1936 users online. 1 members and 1935 guests.
