I have just tried to flash two another kernel I tested before(kernel_AP6210_RK1000_Host_DUAL_2 and kernel_RTL8188_HD_v311a). Both of them work.
[ROM Download] Official Android 4.4 KitKat Firmware For RK3188T TV BOX and TV Sticks
Originally posted by d33 View Post
I have just tried to flash two another kernel I tested before(kernel_AP6210_RK1000_Host_DUAL_2 and kernel_RTL8188_HD_v311a). Both of them work.CS918II/16GB(HTC-031-V1.0 board)
CS918 (TN-BX09_V2.1 2013/05/31) FW: k-r42-old_revision-wasser-1.2.3- fried by 12V PS
K-R42 board version B351_V2.0 1348, wifi Realtek8188ETV , RK3188T;FW: wasser-firmware-kr42-new-1.0.3
Originally posted by digger View PostSorry friend, this last one doesn't want to boot.
Don't bother with my version 2.x/3.x kernels.Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Originally posted by d33 View PostCan you send me DMESG please. ThanksAttached FilesGK525 My mod rom.
Originally posted by d33 View PostInteresting, it boots on my device. Ahh, I see it boots on Rondoval's K-R42 too.
Is it correct way?CS918II/16GB(HTC-031-V1.0 board)
Originally posted by robertnik View PostMy dmesg.Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Originally posted by digger View PostProbably something wrong with boot.img? I didn't change it and use one which is inside the ROM from the post#69.
Is it correct way?Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Originally posted by d33 View PostSame config as me.CS918II/16GB(HTC-031-V1.0 board)
Last edited by d33; 07 April 2014, 21:09.Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Sory, link not work.
But I have a dmesg with stock kernel, where it acts microphone and camera.stock_kernel_dmesg.zipGK525 My mod rom.
Donate to Finless
Donate to Finless
Originally posted by d33 View PostYepp - I can see my kernels are defaulting to LPCM audio support only so even if passthrough works it will only be stereo.
I'll work on that.
Walter77 - Can you get me DMESG of the stock with T428?
Sorry for the delay, my girlfriend...
Here are the files for T428 with stock kernel and with kernel v4022_AP6330_RK1000_Host_DUAL_2Donations are welcome and will be shared with other devs:
DONATIONS
CX-921 TV-Box without Bluetooth (RK3188 / RTL8188 Wifi), CX-921b TV-Box (RK3188T / AP6210 Wifi), T428 TV Stick (RK3188 / AP6330 Wifi), CX919 TV Stick (RK3188 / AP6210 Wifi)
Here is the logged output of your T428 connected to your TV:
Code:<4>[ 1.030469] ******** Show Sink Info ******** <4>[ 1.030500] Support video mode: <4>[ 1.030522] 1920x1080p@60Hz. <4>[ 1.030542] 1920x1080p@50Hz. <4>[ 1.030562] 1280x720p@60Hz. <4>[ 1.030582] 1280x720p@50Hz. <4>[ 1.030600] 720x576p@50Hz. <4>[ 1.030620] 720x480p@60Hz. <4>[ 1.030638] Support audio type: LPCM <4>[ 1.030662] Support audio sample rate: <4>[ 1.030686] 32000 <4>[ 1.030700] 44100 <4>[ 1.030714] 48000 <4>[ 1.030727] 88200 <4>[ 1.030741] 96000 <4>[ 1.030755] 176400 <4>[ 1.030769] 192000 <4>[ 1.030784] Support audio word lenght: <4>[ 1.030808] 16bit <4>[ 1.030822] 20bit <4>[ 1.030836] 24bit <4>[ 1.030850] Support audio type: LPCM <4>[ 1.030873] Support audio sample rate: <4>[ 1.030897] 32000 <4>[ 1.030911] 44100 <4>[ 1.030924] 48000 <4>[ 1.030939] 88200 <4>[ 1.030953] 96000 <4>[ 1.030966] 176400 <4>[ 1.030981] 192000 <4>[ 1.030996] Support audio word lenght: <4>[ 1.031020] 16bit <4>[ 1.031033] 20bit <4>[ 1.031047] 24bit <4>[ 1.031062] Support audio type: AC3 <4>[ 1.031084] Support audio sample rate: <4>[ 1.031108] 32000 <4>[ 1.031122] 44100 <4>[ 1.031135] 48000 <4>[ 1.031149] Support audio word lenght: <4>[ 1.031174] 16bit <4>[ 1.031188] 20bit <4>[ 1.031202] 24bit <4>[ 1.031216] Support audio type: DTS <4>[ 1.031238] Support audio sample rate: <4>[ 1.031262] 32000 <4>[ 1.031276] 44100 <4>[ 1.031290] 48000 <4>[ 1.031304] 88200 <4>[ 1.031318] 96000 <4>[ 1.031332] Support audio word lenght: <4>[ 1.031356] 16bit <4>[ 1.031370] 20bit <4>[ 1.031383] 24bit <4>[ 1.031398] Support audio type: DSD <4>[ 1.031420] Support audio sample rate: <4>[ 1.031444] 44100 <4>[ 1.031458] Support audio word lenght: <4>[ 1.031482] 20bit <4>[ 1.031496] Support audio type: E-AC3 <4>[ 1.031519] Support audio sample rate: <4>[ 1.031543] 44100 <4>[ 1.031557] 48000 <4>[ 1.031572] Support audio word lenght: <4>[ 1.031596] 20bit <4>[ 1.031610] 24bit <4>[ 1.031624] Support audio type: MLP <4>[ 1.031646] Support audio sample rate: <4>[ 1.031670] 48000 <4>[ 1.031684] 96000 <4>[ 1.031698] 192000 <4>[ 1.031713] Support audio word lenght: <4>[ 1.031737] 24bit <4>[ 1.031751] Support audio type: DTS-HD <4>[ 1.031775] Support audio sample rate: <4>[ 1.031799] 48000 <4>[ 1.031813] 96000 <4>[ 1.031827] 192000 <4>[ 1.031841] Support audio word lenght: <4>[ 1.031865] 24bit
Code:<6>[ 4.744166] IT66121: getHDMITX_EDIDBytes(): DDC TimeOut. <6>[ 4.744188] <3>[ 4.744270] (NULL device *): [HDMI] read edid base block error <3>[ 4.744349] (NULL device *): warning: EDID error, assume sink as DVI !!!! <6>[ 4.744433] (NULL device *): warning: no CEA video mode parsed from EDID !!!! <4>[ 4.744548] ******** Show Sink Info ******** <4>[ 4.744599] Support video mode: <4>[ 4.744646] 1920x1080p@60Hz. <4>[ 4.744684] 1920x1080p@50Hz. <4>[ 4.744721] 1920x1080i@60Hz. <4>[ 4.744764] 1920x1080i@50Hz. <4>[ 4.744801] 1920x1080p@30Hz. <4>[ 4.744838] 1920x1080p@25Hz. <4>[ 4.744881] 1920x1080p@24Hz. <4>[ 4.744918] 1280x720p@60Hz. <4>[ 4.744953] 1280x720p@50Hz. <4>[ 4.744995] 1280x720p@30Hz. <4>[ 4.745032] 1280x720p@25Hz. <4>[ 4.745067] 1280x720p@24Hz. <4>[ 4.745103] 720x576p@50Hz. <4>[ 4.745144] 720x480p@60Hz. <4>[ 4.745179] ******** Show Sink Info ********
Donate to Finless
with real HDMI Input supporting all resolutions and framerates between 24~83 KHz(H)/ 50~75 Hz(V).
Do you have something connected with dvi? I think DVI will not provide all EDID informations.Donations are welcome and will be shared with other devs:
DONATIONS
There are currently 2006 users online. 0 members and 2006 guests.
