work with this latest 4.4 KK from rk ?
[ROM Download] Official Android 4.4 KitKat Firmware For RK3188T TV BOX and TV Sticks
Another 4.4.2 rom show up this time for MK902
FileFactory is the best place to upload and share files with no limits since 2005. Send and receive any type of file up to a massive 5GB with unlimited file bandwidth.
More details here:http://chinagadgetsreviews.blogspot....-firmware.html
Originally posted by d33 View PostIf you could grab DMESG from stock and from my v4021 via ADB that would be really helpful
Sent from my iPhone using TapatalkAttached Files
Many thanks very useful
Sent from my iPhone using TapatalkMeasy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Originally posted by goodoane View PostAnother 4.4.2 rom show up this time for MK902
Anyone got my firmware booted on devices other than AP6210?
I have an EKB31B MT7601 wifi chip and use bootloader v2.08 and Finless bootlarge.img and MT7601 Test kernel from d33, it shows the Android bootlogo and then the Android homescreen for 1 second but then jumps back to the bootscreen in an infinite loop.
Anyone who can help me?
Donate to Finless
2. Do not use kernels 3.x or 2.x
3. New boot.img is needed, don't use Bob's beta boot.img
We are working on this.Measy U4B (=Tronsmart T428) used by my kids!
Donate to Finless
Does your v4 kernel work with this new KitKat ROM?
I've flashed so many roms, I don't want to flash unneccesary.
Why is this kernel so much bigger, changes?
What are the correct HDMI settings to use in the config file for all these TV Boxes with AV Out & RK1000 sound? Some use lcd0, some use lcd1, others both, dual display, no dual display? It's very confusing.
I have the MT7601 wifi patch for Android 4.2, maybe someone can merge it into radxa Android KitKat source or the beta or other Android KitKat source.
Since KitKat use wifi differently than Android 4.2 it's not very straight forward into merging it.
But I have seen in the KitKat sources, there is mention of using Android 4.2 wifi method instead of KitKat method.
KitKat Android Source Changes needed for MT7601U Wifi
Here is the patch - https://github.com/roondar/wiki-rock...BC20130620.zip
In /hardware/libhardware_legacy/wifi/Android.mk, you must change wifi.c(new KitKat 4.4 wifi file) to wifi.old since that is the same wifi file(wifi.c) as on Android 4.2(and the patch).
Don't know how to enable Android 4.2 wifi compatibility properly in those files.
In system/netd there are also 4 files that need to be changed but don't know how to make it more compatible with KitKat as it's for Jellybean, maybe search for MT7601 inside the patch files and copy those parts into the KitKat files?
If you open the libhardware_legacy.so(KitKat) file in a hex editor, you see lots of reference to Broadcom AP6210 references at the end of the file. If you open that file in the stock MT7601, EKB311B JB firmware, you see lots of references to Mediatek MT7601.
Donate to Finless
Just installed KitKat_T010_AP6210_public_20140403 with your Kernel "kernel_AP6210_RK1000_Host_DUAL_2" on CX-921b TV-Box with AP6210 RK3188T, box has only HDMI and analog audio output, Box has no SPDIF.
Results:
Fast boot, android is fast, feels good.
CPU-Z shows 312-1.61 GHz no lock to 1.4!
Antutu scored 19388!! Best score ever with 1080p kernel!
ethernet - works, about 8-9 MB/s
wifi - works
bluetooth - works
Display Settings HDMI:
1080p 60 - works
1080p 50 - works
720p 60 - works
720p 50 - works
720x576p 50 - works
720x480p 60 - works
After changing resolution there is a little pink line on the left
After reboot no pink line anymore
Screen scaling lost after reboot! Have to adjust it again!
Power Off - works, led turns off
Sound Device Manger Shows:
RK29_RK1000
RK29_RK1000 5Point1Multichannel
RK29_RK1000 PASSTHROUGH
Played with internal player/BS Player - HDMI audio test:
RK29_RK1000 - on - no audio
RK29_RK1000 5Point1Multichannel - no audio
RK29_RK1000 PASSTHROUGH on - no audio
No audio at all over hdmi!
Played with internal player/BS Player/internal - analog audio test direct from box:
RK29_RK1000 - on - perfect!
RK29_RK1000 5Point1Multichannel - seems to work, but strange channels because of stereo output.
RK29_RK1000 PASSTHROUGH on - short noise, android auto mute i think.
Played with internal player/BS Player - Video playback test:
1080p 24fps - perfect
720p 24fps - perfect
Beyond XBMC 12.4 Beta 3.4:
System shows 1920x1080@60Gz - Full Screen ( about 70-80 fps )
Analog audio - works
1080p - about 15 fps, extrem stutter
720p - perfect!
GOTHAM XBMC 13 Beta 2:
System shows 1920x1080@60Gz - Full Screen ( about 30 fps )
doesn't matter if passthrough is selected
1080p - perfect playback!!
720p - perfect playback!!
That's it for now.
So for CX921b AP6210 ( quite the same as T-R42 old i think ), we only need ;-)
1. HDMI audio passthrough in XBMC Gotham
2. Real 24p and 25p HDMI mode in android Display settings for 1080/720
Keep on guys!!
P.S.
tried with "kernel_AP6210-alt_RK1000_Host_DUAL_2.img" box will not boot!
tried with "kernel_MT7601_RK1000_Host_DUAL_2.img" box will boot, only ethernet works, no wifi or bt, analog audio works, still no hdmi audio or passthrough
tried with "kernel_AP6330_RK1000_Host_DUAL_2.img" box will boot, only ethernet works, no wifi or bt, analog audio works, still no hdmi audio or passthroughDonations are welcome and will be shared with other devs:
DONATIONS
CX-921 TV-Box without Bluetooth (RK3188 / RTL8188 Wifi), CX-921b TV-Box (RK3188T / AP6210 Wifi), T428 TV Stick (RK3188 / AP6330 Wifi), CX919 TV Stick (RK3188 / AP6210 Wifi)
Originally posted by d33 View PostNot Found
The requested URL /d33/kernels_v4022.zip was not found on this server.
GK525 My mod rom.
There are currently 3509 users online. 0 members and 3509 guests.
